Those who have made their own harness...Come in
Old 01-05-2009 | 06:26 AM
Jones'n's Avatar
No, it is done through the TAC module.
Old 01-05-2009 | 10:13 AM
samh_08's Avatar
Couple questions again.
!.) Is there anyway to know FORSURE if my PCM can control a cable TB before I wire everything up and try to start it.
2.) How much of a DBW systems gayness can actually be tuned out
3.) Can I just pick up and random TAC module and pedal IF I did decide to stay DBW
Let me know, thanks.
Sam
Old 01-05-2009 | 02:19 PM
waynehartwig's Avatar
Thanks! After a search of TAC I found a wiring diagram and it makes sense now
EDIT: went looking for the diagram I found before, and I couldn't find it again, but I found this thread So here is the link...
http://www.lt1swap.com/dbw.htm
Old 02-08-2010 | 08:21 PM
TipsyMcStagger's Avatar
Originally Posted by ryanvv355
Delphi deleted the IAC driver in most 03 and later PCMs due to GM mainly using DBW at that point.
Bump for a hypothetical question; Based on the above statement, is it accurate to say you'd be better off acquiring a pre- '03 PCM if you're still in the planning stage and haven't yet determined whether you'll be going DBC or DBW?
Any particular PCM to look for that would offer the most flexibility?
TIA.
Tipsy
Old 04-04-2010 | 01:50 PM
pechitoperu1's Avatar
Hi I'm new at this but I need it to ask you a question my proyect is a 79 firebird and im going to put a vortec gen3 w electronic trottle... now my question is i got the wiring harness all up to the fuse box by the computer... now i now i need the pedal and the obdII did you have any diagrams that may help me? i know i may have to override the antithef also. Thanks
Old 04-04-2010 | 08:55 PM
fptransport's Avatar
pechito you need the pedal but also the harness the goes from the pedal to a module.
Old 04-25-2010 | 04:56 PM
LS88FoxBody's Avatar
Originally Posted by poconojoe
He listed his service number as 12589462, it isn't on the list of interchangable Blue and green plugged PCM's that I have. Which include
12576106
12583560
12583561
12586242
12586243
12589463
By the way, why do you feel that DBW makes the the under the hood look cleaner? You have more wiring and a TAC module to deal with. I know everybody is intitled to their opinion, but cleaner to me means less stufff.
So if I had my harness originally was running a 12576106 pcm ,and I added the dbc parts to the harness would it be better to run that pcm or re pin a few to use the 411 pcm. I'm just curious as I Have both but the harness was made on the 12576106 pcm
Old 04-26-2010 | 07:53 PM
busta9876's Avatar
Sam
I have verified the following have Idle motor stepper driver installed:
2003: Serv. No. 12576106 with Hwd. No. 12570558 -
2004: Serv. No. 12586243 with Hwd. No. 12583659 -
2005-2006: Serv. No. 12589462 with Hwd. No. 12589161 -
pull the cover off the PCM, look for pins sticking through circuit board. If you have PINS, your got the stepper motor driver in your PCM.
Old 04-26-2010 | 08:15 PM
Hi Volume's Avatar
Default Need help with 02 5.3/4l60e swap with 98 Ls1 auto wiring.
sorry, i screwed up. delete this
