Gto vats bypass
Old Jan 7, 2009 | 12:25 AM
Nissankat's Avatar
Default Gto vats bypass
So I just picked up a rear ended gto that I plan to pull the motor from to put into my 240sx. Before I pull the motor from the gto I would like to get it started to be sure its in running order. I found the key in the car sitting in a pool of rain water where it appeared to have sat for a while. What I would like to know is if the electronics in the key would have to be functional for the vats to not prevent me from starting the car and if so how can I bypass the vats on the gto? Will the resister method work? Thank you and sorry if this is a newb question.
Old Jan 7, 2009 | 05:23 AM
poconojoe's Avatar
Measure the key and put the resister in if it has one
Old Jan 7, 2009 | 11:18 AM
Nissankat's Avatar
I am unsure if it is that ez with the gto since there is so much electronic stuff in the key. The post for the security deal is attached to the board in the key but the board is all rusty and unoperational.
Old Jan 7, 2009 | 01:22 PM
poconojoe's Avatar
What year? If its 2004 I could turn off the vats in your PCM, but you'd have to jump the starter circuit to get it to crank
Post a picture of the key
Old Jan 8, 2009 | 02:15 PM
Smo's04Gto's Avatar
If the key works to unlock or lock the car your good to go.If not you need the bypass.Good luck with the swap for $25 alldata you can get all the info you need on the GTO That's what I did and it was very helpfull,I could also get you some info if need be.
