recomended shift points?
Old Oct 2, 2003 | 12:05 AM
Flyman's Avatar
Default recomended shift points?
How does one determin the best shift points for there application when getting the PCM reprogrammed?
I have a 1998 jeep wrangler with the 2001 ls1 (5.7L) and 4L60E, I'm not going to rock crawl and I'm not going to the drag strip
any recommendations?
Thanks
Old Oct 2, 2003 | 12:17 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: recomended shift points?
If the engine is basically stock and the vehicle will be used for "normal" use, I would leave the shift points stock and just make sure you enter the correct gear ratio and tire size when you get the PCM reprogrammed. That way, the PCM knows the correct vehicle speed and can choose ideal shift points based on that.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Oct 2, 2003 | 12:27 AM
Flyman's Avatar
John
Thanks for the fast reply, do you ever sleep or are you a night shifter like me, anyways i also sent an e-mail about an hour ago, did you get it?
Old Oct 2, 2003 | 12:43 AM
Speartech's Avatar
Yeah I sleep; just not as much as I'd like to.
I might have gotten the email if you're Steve.
__________________
www.speartech.com
