motor mounts
Old Jan 8, 2009 | 08:11 PM
billyflantos's Avatar
Default motor mounts
i'm putting a 6.0 in a 85 regal whick motor mounts do i need jegs has them for any small chevy chassis or s-10 chassis
Old Jan 9, 2009 | 10:13 AM
ttttt
Old Jan 9, 2009 | 11:16 AM
diognes56's Avatar
Check out Year One. Go to their online shopping for your car and do a search for BG980. BRP Hotrods also has a conversion kit. I am sure there are others, maybe somebody else will chime in.
David
Old Jan 9, 2009 | 11:41 AM
hookemdevils22's Avatar
fab some.
It's not difficult.
Old Jan 9, 2009 | 04:20 PM
Rat Chevelle's Avatar
I have some for sale, if interested reply, they are very easy to fab, but for the price these will save you some headaches.
visit this link to see them and more info.
http://phoenix.craigslist.org/evl/pts/970546108.html
thanks
Rat Chevelle
Old Jan 9, 2009 | 06:16 PM
thanks
Old Jan 13, 2009 | 10:59 AM
ERKEL's Avatar
trans-dapt #4592 and you can use the factory gm upper mounts for the mid 70's camaro.
Old Jan 13, 2009 | 11:28 AM
bczee's Avatar
Most of the Adapter plates that are on the market are built to be using Chevy SBC frame stands. You would need to also replace those with some like year Chevy A-Body Frame stands.
Once you replace those. You can pertty much use any of the Aftermarket adapter plates, depending on where you want to mount the engine (back/forward, up or down in the engine bay they all can be a bit different). If you use the old style of BRP plate, which calls for relocation of the Frame mounts on the crossmember, you can position the engine where you need and want it anyway. The S&P style of mounts would leave the SBC frame stand in the OEM Location (chevy that is) and uses different mount location to position the engine, they have standard location and 1" back.
You can fab up your own plates from the template in the FAQ/Sticky. It is not hard, I did mine at home with just the usual tools, cutting wheel, grinder, drill, tab, Powder coated them and they look like any other aftermarket vendors.
Old Jan 13, 2009 | 12:30 PM
the_merv's Avatar
Veteran: Air Force
I bought some on Ebay for $40 shipped, came with the plates machined and all the hardware.
