my newest creation 5.3.in a what??????
Location: sneaking in your back door as you leave!/cartersville ga
pretty close maybe a little more, but look at the bumpstop. it compressess approx. 3 inches. it essentially collapses in itself.
one thing i have found. you do not need much compression. i always like droop more. and i even limit that also
th
th
she is running! i originally tried to use a comp. out of a 00 vette. and tried to reflash it w/ a f-body file. it would not allow me to do it. it said different operating systems???? so luckily i had another f-fody comp. on the shelf..lucky me.
i am new to the EFILIVE so if someone could tell me what i need to do w/ the other comp. to make it compatible i would appreciate it...........im just used to using the FAST XFI system....alot less paremeters
well it ran flawless. we took it out on sunday to a local place to try it out. it sure beats the old tbi motor that i took out lol
Nice rig.
Mine is in the early stages right now. Frame rails are done just need to get them cleaned up and crossmembers welded in. From there the money should start disappearing rather quickly.
What manifolds did you use? That si one of my concerns right now.
Thats an interesting pedal setup... is the throttle the small rod under the brake? I've never seen anything like that before. Same with only the 2 small gauges. What are they?
I used a set of factory stainless corvette manifolds. I cut the factory collector off a d modified the lenghth and put a different collector on them. And of course I relocated the o2 sensors as well
