Carb'd & front mount Distributor, fox swap is ALIVE
Old 01-25-2009, 08:12 AM
skidmarkSS's Avatar
Originally Posted by SOM68SS
Nope drivers lower. I'm modifying the BMR Drag race braket to work with the Iron Block
i have the same BMR kit,don't think i am going to use it though.bad *** motor,i will get pics of mine up as soon as it is done.
Old 01-25-2009, 04:32 PM
Qwiknotch's Avatar
is that the AJE k-member? If so, I am pretty stoked because that engine is set back pretty far. I like it.
Old 01-26-2009, 07:49 AM
SOM68SS's Avatar
Yeah that is the AJE unitother than mine being a little tweaked "bought it used" the fit was great. Everything went where it was supposed to. I highly recomend using a F-Body, Vette, or some other shallow pan though.
Old 01-27-2009, 02:10 AM
crpndeth's Avatar
Default Ac will it go
I have fought the good fight and won. FInally after countless hours working/sorting through setbacks and bad weather my LSX powered notch is alive. Here are some update pics and a link to a video
http://www.youtube.com/watch?v=mMRZJfpsixk
More detail can be found on my blog
http://www.mylrs.com/blogs/lrs/archi...live-quot.aspx
any possible way lower mounted i'm doing the same thing and i want to keep ac on car did the front cover bring the crank pulley out farther,or is it still the same geometry.
Old 01-27-2009, 08:11 AM
SOM68SS's Avatar
Crank pulley is in the same location, however you have to use a smaller diameter balancer to clear the bulge and timing pointer.
Old 01-27-2009, 04:36 PM
Qwiknotch's Avatar
I was going to buy the low profile 7qt Moroso pan. Has a windage tray and trap door, pretty neat piece. I have 2" drop spindles, so my car sits really low.
It looks like I can use a factory ford radiator too.
Do you have any pics of it from the side? I just want to see how close to the firewall it is. thanks
Old 01-27-2009, 04:57 PM
SOM68SS's Avatar
That is a Mishimoto radiator designed for the 79-93 fox cars. I will try and get a side shot of it. I have about 3/4" -1" clearance between the rear of the passenger side head and the firewall. The drivers side has more room.
Old 01-27-2009, 09:02 PM
blck89rs's Avatar
how do you have the lower return hose on the driver side? every w/p ive seen for the lsx has it on the passenger side crossing the front of the engine? im very clueless can you please help
Old 01-27-2009, 09:30 PM
SOM68SS's Avatar
The Meizere has openings for both sides of the water pump. I just used a factory Ford lower radiator hose for the fox mustang
Old 02-07-2009, 01:39 AM
dkbykesdk's Avatar
is there some drilling you have to do for oile the cam gears an distributor gear???
any pictures tips thanks,
looks good
Old 02-07-2009, 09:56 PM
TJ
TJ's Avatar
Originally Posted by alocker
You should have painted it Ford blue and no one would know its an LS. Clean install.
kit uses a ford dist. might as well paint it blue.
very clean.
youve got a wide open engine bay.
nice setup!
Old 02-08-2009, 06:43 PM
  #32
SOM68SS's Avatar
looks good
The Front mount distributor kit comes with instructions and a template to drill the cam retainer plate for the oiling holes. At first I thought there was no way the 2 tiny holes would supply enough oil but I was wrong it provides more than enough.
Old 02-08-2009, 07:05 PM
  #33
dkbykesdk's Avatar
thanks alot it should be in soon, i have motor plates so i might have to get some headers amde cuz im not sure the motor sits i the same place as the aje kmember would have put it.
Old 02-09-2009, 02:24 PM
  #34
dkbykesdk's Avatar
what did you do for a oil pressure sending unit???
Old 02-09-2009, 02:51 PM
  #35
SOM68SS's Avatar
I used a metric adapter and hooked up a mechanical oil pressure gauge where the stock sending unit would have gone on the back of the block.
Old 02-11-2009, 05:27 PM
  #36
Slow Z28's Avatar
what part number distributor did you use? any alterations to the distributor or pretty much just drop in?
what balancer part # did you use? I'm in the process of doing this and don't want to be ordering up the wrong parts, haha
Old 02-11-2009, 10:03 PM
  #37
dkbykesdk's Avatar
pictures part number?? would be appreciated
Old 02-12-2009, 08:12 AM
  #38
SOM68SS's Avatar
Balancer is this one
http://store.summitracing.com/partde...5&autoview=sku
Distributor is a MSD-8579
http://www.latemodelrestoration.com/...0%201&comp=LRS
it was a drop in unit. The Front mount conversion gives you a list of distributors you can use.
I don't know the part number of the oil pressure adapter I used it was just a brass fitting that had the OEM sending unit thread pitch on the male side and reduced it to a standard 3/8 NPT that is found on all the mechanical oil pressure gauges.
Old 02-12-2009, 09:41 AM
  #39
TJ
TJ's Avatar
metric adapter link
http://store.summitracing.com/egnsea...02495&D=302495
oil pressure port in the back of the block is 16mm i believe.
the head ports are 12mm.
Old 02-18-2009, 11:28 AM
  #40
dkbykesdk's Avatar
[QUOTE=SOM68SS;11037485]Balancer is this one
IF YOU USED THIS PULLEY HOW DID YOU KNOW WHERE TO PUT IT ON AT CUZ THERE IS NO KEYWAY IN THE CCRANK SO HOW DO YOU KNOW IF YOU TIMING IS RIGHT,
SORRY FOR ALL THE QUESITONS
Quick Reply: Carb'd & front mount Distributor, fox swap is ALIVE
