Coil bracket problem...
Old Jan 14, 2009 | 05:28 PM
sman's Avatar
Default Coil bracket problem...
Putting the 5.3 in the camaro, im using an ls1 intake, injectors, fuel rail, but also using the truck centerbolt valve covers, coil brackets, and coils.
My problem, the inlet on the ls1 rail hits the driver side coil pack bracket and one of the coils.
Should I buy ls1 brackets, if so what year? Will the truck coils fit in the ls1 brackets? Or should I try and modify the rail or bracket, where would I begin?
Old Jan 14, 2009 | 06:19 PM
djquik88's Avatar
My friend just ran into the same issue. We just bought a set of aftermarket fuel rails.
Old Jan 14, 2009 | 07:37 PM
poconojoe's Avatar
The truck coils do not fit on the F-body rails
Old Jan 14, 2009 | 08:17 PM
ls1nova71's Avatar
You can just carefully bend the inlet either up or back slightly to clear the coil.
Attached Thumbnails Coil bracket problem...-photo0805.jpg   Coil bracket problem...-photo0804.jpg
Old Jan 15, 2009 | 06:42 PM
NemeSS's Avatar
yea just bend the inlet some,
works great no prob
Old Jan 15, 2009 | 07:00 PM
thunderstruck507's Avatar
carefully bend...no problem
some people must just love spending money
Old Jan 16, 2009 | 02:36 PM
sman's Avatar
If and only if, there was no fuel in it, would heating it up with a torch cause less stress on it, or is that a bad situation?
Old Jan 16, 2009 | 03:53 PM
the_merv's Avatar
Veteran: Air Force
Is this for the circle Truck Coils?
I have LS2 Rails and the circle Truck ones, and I have no problems..
Old Jan 16, 2009 | 06:00 PM
Do not heat it...just put a socket or something over it and go slow
Dunno how much difference it makes (i don't recall any) but I did turn my rails around so the inlet is on the pass side since thats where it was easier to run a fuel line, but I'm 99% sure it looked about the same either way
This is with the square truck coils
Old Jan 19, 2009 | 12:43 PM
sman's Avatar
Yep, the square truck coils, I think. Im going to try this tonight, ill let you know how it goes. (fingers crossed)
Old Jan 23, 2009 | 11:21 AM
sman's Avatar
All went well, but I just thought id share, these coils are round. Not sure if that helps anyone or not since it was brought up.
Old Feb 17, 2009 | 01:09 PM
the450r's Avatar
i was going do a simular swap for mounting holes on the truck valve covers vs my ls1 covers have no mounting holes on the lower side. do the coil brackets swap between valve covers?
the pics of the engine and trans are my setup and i need valve covers that have the hole for the mounting bolt. I have a 02 4.8 truck that has mounting hole below the coil bracket.
Attached Thumbnails Coil bracket problem...-getattachment.jpg   Coil bracket problem...-picture-266.jpg   Coil bracket problem...-picture-268.jpg
By Brett Foote | 2026-06-04 05:00:17
