Oil pan sealing?
Thanks,
Mike
No sarcasm here - a reminder to self to not overthink the problem!! Just because I have an air compressor doesn't mean it has to be used everywhere. :-))
Thanks,
Mike
When I welded the bung in my trans pan I used gas to check it. I figured the gas was thinner than water so more likely to leak. If I would have had alcohol available I would have used that........thinner solvent = more likely to leak and I wanted to find the leaks before I put that trans pan back up.
Any suggestions as to some non-metallic solutions? JB Weld? Devcon Metal Repair epoxies??
Thanks,
Leaky Mike
Heat the pan up pretty hot to boil anything out then clean the area with rubbing alcohol and let the alcohol leak through the porosity then cool down. Heat it up again to around 150F then apply loctite (it must be for already assembled fasteners). As it cools the contracting air in the porosity will pull the loctite in and then it will set up because the porosity is generally the same size gaps as fasteners have in them. If u've got access to a vacuum tank it works even better. That's what they use to do the castings. The vacuum helps draw it in too.
