Fuel pump/Fuel tank
Hi Guys ...
I am thinking about doing my own fuel tank/pump,But i am wondering cab the o.e. sending unit be modified to work?Also on a stock ls2 what pump and does anyone have a part number. I am gong to use a corvette fuel filter. Any ideas? Thanks .P.s. I am doing this because i am cheap , i can get the tank with pump for 600.00 dollars.
I agree with lsxmalibu. I installed a big block sending unit in my cutlass which has a 3/8 feed and 1/4 return or vent which can be used for the return line form the vet filter/reg. The first google search I found one for a 1969 camaro if they are the same as your 67 then that is all you need. I assume your tank allready has a vent line in it, my cutlass did.
LS1Tech Premium Sponsor
Hi Guys ...
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
