brp vs edelbrock?
Old Mar 22, 2009 | 03:33 PM
  #41
SkylarkLS1's Avatar
Originally Posted by obfpd172
After reading the post I am still confused on what combination will work in my 64 chevelle. It sounds like the f-body oil pan will not work, but maybe a cts oil pan will. Is this right. This is for the Edelbrock mounts. I have a 99 ls1 from a camaro with all the accessories. Can anyone confirm this
The f-body pan will not work, it will hit your crossmember. My 64 is going with edelbrock adapter plates with edelbrock headers and milodon oil pan. Everyone goes different routes lh8/autokraft/S&P modified. If you are using edelbrock plates go off their recommendation. There was a tech from Edelbrock on here I forgot his User ID however..Someone can chime in
Old Mar 23, 2009 | 05:16 AM
  #42
rocco T's Avatar
Default G bod
Ok, so for my 85 Monte SS....is it the same thoughts with BRP or do I go with someone else?
Old Oct 26, 2009 | 08:28 PM
  #43
pushrod36's Avatar
Default Confused about what fits
Has anyone used the CTS-V oil pan with the edelbrock kit in a 68-72 pontiac? I feel like I saw on the forums that some people have, but the guy at edelbrock told me that he tried that pan and it did not fit. I would like to use the autokraft pan, but I have been waiting for over a month and the guy is back ordered. I would like to avoid the milidon pan because it is expensive and doesn't seem to have the level of engineering to justify its price.
Old Oct 27, 2009 | 04:46 PM
  #44
neal64ss's Avatar
Here is a new option that will be available soon. Expensive, but probably cheaper in the long run.
http://jzmotorworks.com/LS1Pan.html
