brp vs edelbrock?
Old 02-04-2009, 09:24 AM
jsn829's Avatar
Does the Edelbrock retro kit sit the engine close to the stock location and angle?
Old 02-04-2009, 09:39 AM
alocker's Avatar
Yes, it is designed to keep everything stock from the bellhousing back. Mine were within 1/2 inch and all the stock bolt holes worked with the trans x-member.
http://www.edelbrock.com/automotive_.../6000/6701.pdf
Old 02-04-2009, 11:42 AM
jsn829's Avatar
Since my engine mounts are from a pontiac and looks like they used chevy mounts, does someone make a nice afermarket mount?
Old 02-04-2009, 12:30 PM
2plus2's Avatar
Too bad neither edelbrock nor brp make mounts for a 67 impala
Old 02-04-2009, 05:41 PM
olblue51's Avatar
Originally Posted by the450r
i was going to get BRP because i can retain the factory F body accessories and im doing a T56 in an auto car so i gotta cut the floor anyway. and the rear crossmember comes with it so u dont have to do alot of work setting the pinion angle. just get adjustable rear arms to set the pinion angle. Im not lowering my car so i wont have an issue with the axle being higher than the trans.
from what ive read about the Adaptor plates. They require alot of fabricating and mount/spacer problems setting the engine in expecially on Pontiac frames.
The BRP motor mounts and crossmember take more work to fit than adapter plates... at least it did in my case and many others I've heard from. Don't be fooled by how simple they make it seem... it's not a bolt in deal.
My Edelbrock plates bolted right up... no fabricating or space issues. Some I've heard have to move the frame mounts and some don't. With the BRP kit you had to move them no matter what, even with the LH8 oil pan.
Old 02-04-2009, 05:48 PM
jsn829's Avatar
How does the lh8 pan fit with the Edelbrock kit? Is there a better pan for the kit?
Old 02-04-2009, 06:11 PM
olblue51's Avatar
I'm sure the LH8 Hummer pan would fit fine with the Edelbrock kit but the problem is the damn thing hangs so low below the crossmember. But it does that with any kit.
I remember the instructions for my F-body Edelbrock adapter plates (which are the same for your A-body) recommended an aftermarket oil pan from Milidon... I don't remember the part number but I do remember it was expensive.
As far as your car goes, I couldn't tell you what GM pan would work. You might want to search in this forum and if you can't find an answer start a new thread and ask the A-body guys what oil pan they are using.
I think someone earlier recommended the Autokraft pan. I've heard nothing but good things about that pan but it's also aftermarket and might be a little pricey.
Old 02-04-2009, 06:22 PM
alocker's Avatar
The edelbrock mounts should work great in your car. The problem is getting headers to fit.
Old 02-04-2009, 06:45 PM
kevin 67/6.0's Avatar
I used the hookers and had no prob. https://ls1tech.com/forums/conversio...hevelle-5.html
Old 02-04-2009, 07:08 PM
13 Second Truck Club
726.0chevelle's Avatar
eldelbrock got mine for 550 shipped they are nice im usin a cts pan hopefully it wont hang down too low
Old 02-04-2009, 07:27 PM
olblue51's Avatar
Edelbrock actually recommends that oil pan (part # 12577901) for the F-body in their instruction sheet.
The part number for the Milidon oil pan I mentioned earlier is 30915. Edelbrock claims that is the oil pan they used when they fit their adapter plates to a chassis.
Old 02-04-2009, 11:38 PM
  #32
jsn829's Avatar
You dont have to cut the trans tunnel with the 4l60e do you?
Old 02-05-2009, 06:14 PM
  #33
jsn829's Avatar
Anyone?
Old 02-05-2009, 06:30 PM
  #34
my 4l80 fit when i moched it up. with the mounts that i used. not sure about edelbrock
Old 02-05-2009, 07:09 PM
  #35
2006_Superado's Avatar
was that for just the headers?... or did you get there mounts too?.
Old 02-05-2009, 07:50 PM
  #36
just headers i made the mounts they were easy to make and only costed about $20 used the stock tranny crossmember only had to cut about 6 inches out the middle and lower that piece down about 3/4 inch
Old 02-05-2009, 08:14 PM
  #37
i don't have any type of metal fabricating tools (welder, plasma cutter, and such) just a lot of hand and power tools and a small 2 car garage.
i've worked on cars my whole life so there is no question if i can do it, i just don't have the equipment nessecary to fabricate anything, i would love to but i can't put up the cash for all of that right now.. unless you could convince me that it would be cheaper in the end somehow, but i doubt it.
so for no i'm trying to find the cheapest mount and pan combo that will work in my 73 nova without needing any modifications, and still allow me to use off the shelf headers in the future. i would like to leave everything as is on the LQ9 heck i would even use the pan if i did'nt know it will just cause me big problems in the future.. i'm going to go as cheap as possible on this project as i can without sacrificing safety or reliability.
Old 02-05-2009, 08:25 PM
  #38
the450r's Avatar
the pan part #12577901 do u know which pan this is?
Old 02-05-2009, 09:32 PM
  #39
olblue51's Avatar
It's the Cadillac CTS-V pan...
Cadillac CTSv :
Capacity: 5.5 qts
Oil pan: 12577901
Oil pump pickup: 12577906
Windage tray: 12558268 (same as Truck "C/K)
Dipstick tube: ?
Dipstick: ?
O-ring for Oil pump pickup:?
Oil pan baffle: 12577904
Old 03-22-2009, 02:50 PM
  #40
obfpd172's Avatar
After reading the post I am still confused on what combination will work in my 64 chevelle. It sounds like the f-body oil pan will not work, but maybe a cts oil pan will. Is this right. This is for the Edelbrock mounts. I have a 99 ls1 from a camaro with all the accessories. Can anyone confirm this
Quick Reply: brp vs edelbrock?
