Best engine combo for 1990 Miata.
Ok so best years for wiring? Is there a write up on how to by pass the chip in the key for the stock GM ecu? I have a hold of a 2004 Escalade LQ9 motor for dirt $1,100 with 55k on it. I also found a T56 out of a 02 Trans am with 60k for $1,000. Anything will help. Im an ase tech but I would like to know that Im getting my self into before Starting this. Im going for 450-500 whp after time.
Thanks so much James.
Jim C.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
That is a great deal on the T56!
As for best years, 02 LS1s have LS6 intakes already.
Or go LS2 (6.0) or LS3 (6.2). No more weight, but more displacement. Should make your whp #s easier to obtain (especially the LS3) if you can swing it. DBW TBs are easy enough to make work.
Does all the LS1 stuff bolt onto a 5.3 (tranny, flywheel starter, ECU)????
d
I make over 400 RWHP & RWTQ w/an LS1 (5.7L), NA. You can make 500 RWHP, NA, w/ the proper heads/cam/intake/headers/tune. Look in the dyno section & search. You will find many 5.7L cars producing these numbers.
Keep hearing about how Miata's are traction limited; not if you know how to set up the gearing, suspension & tire combo.
Me personally I like the idea of either the aluminum 5.3 or 5.7 with cam, heads and intake that will easily make power to 7,000-7,500. That would kill a little of the bottom end but make good power in the mid to upper RPM range where the light weight will really shine. Please keep in mind that these are just my opinions and despite what any of us say build it the way you want as you are the one who will be driving it. With that said good luck and keep us posted.Jim C.
