Hello, just thought Id drop a line...
that was supposed to be for my wiring harness and now my work might be going on strike
New clutch slave cylinder bracket off Ebay for 50.00 bucks. Its actually nicer than I expected. Im just lining up the slave cylinder to my clutch pedal now.
I also bought some injectors, fuel rail and intake from LQ9CHEVELLE. I guess the factory truck injectors wont work (from what Ive heard) and the ugly truck fuel rail is 6'' above the ls1 intake.
I also guess Ive just had some bad luck lately, because I went to send off my wiring harness and computer to Wait4me performance and I could not find it? The only thing I can guess is it got thrown away when my brother cleared a spot to store his truck in my garage
But I found the wheels I plan to buy. Intro GTsports.....SICK
ALSO Kj598bbc HERE IS THE WEBSITE I WAS LOOKING AT FOR THE LS6 INTAKE SWAP
http://www.performancetrucks.net/for...t=359987&pp=10
http://www.actionspeedshop.com/parts...duct_info.html
First all, great job so far and I'm following along with you for inspiration!!! I have a 69 Chevelle with no drivetrain and really would like to do a build like this.
Do you have any pictures you can share of your trans tunnel modifications? Did you use a kit of some sort or did you fabricate yourself? This is the one part of the build I haven't convinced myself I can do. I've always wanted LS motor with a 5 or 6 speed manual..
thx
As far as cutting the tunnel yourself I guess there are kits available that require very little cutting for fitting a t56 into 68-72 A-bodys that anybody can do. The reason I cut my tunnel is I wanted to have the engine sit back and as low as possible which the kit does not allow and I didnt have that much cash to spend on a kit. Here is a link:
http://www.brphotrods.com/1968-1972%...0a%20body.html
Hope this helps.
I'm 99% sure this is the route I'm going to take with my car. I now need to find a motor and a t56!!!
In smoothing your firewall, I see you also removed and/or covered the heater hose attachments thru the firewall. What's your plan going forward?? A Vintage Air system?? Just curious as I'd like to smooth my firewall as well, but don't have it in my budget now for a Vintage system. Just wondering what other options are out there.
thx
This is the cheapest heater only unit I can find that Is actually hidden under the dash. I was planning on going with the upgraded hurricane unit that has defrost. Hope this helps.
ttp://www.oldairproducts.com/catalog/index.php?cPath=30000000_32000000_32300000_3230200 0
I'm deep into a swap of my own and my accessories (specifically my power steering pump) doesnt clear my steering box. My motor/accessories are from an Isuzu delivery truck, so does that mean our accessories are different? I assumed that (for the most part) anything with an LQ4 or LQ9 had the same accessories. Your pics make it look like you have miles of room between the power steering pump and the box.
How much clearance do you have there, and did you have to change / modify anything to get that clearance?
Thanks and great build!
