O2 sensors
Old Feb 9, 2009 | 02:22 PM
V8Rumble's Avatar
Exclamation O2 sensors
Hey all, just a real quick question -
Does anyone know if the front O2 sensors for the 2007/2008 L92 engines interchange with any other applications?? I'd REALLY prefer not to spend > $150 each if I can avoid it...
Thanks.
Old Feb 9, 2009 | 09:00 PM
alocker's Avatar
www.rockauto.com
You can get both of them for less than that. I paid about $63.00 each when most placed charge about $125.00. Trust me, I looked too. You probably can use another type and splice them, but I like the plug and play.
Old Feb 10, 2009 | 03:39 PM
V8Rumble's Avatar
Right, thanks. I ordered from rockauto once, it didn't work out so well.
What I'm really hoping for is that someone might know that the O2 sensor for the '07/'08 L92 engines is the same as some other application. Ideally something that's more-realistically priced...
Thanks again though.
Old Feb 11, 2009 | 11:45 AM
V8Rumble's Avatar
Anyone?
(thanks in advance)
Old Feb 11, 2009 | 06:38 PM
V8Rumble's Avatar
OK, I've called around to a couple of departments at Bosch (big thanks to Navy Blue 01 B4C for the initial pointer!), & was then referred to a specialized small company that works with Bosch in a Grand Am racing series. After the discussion that I had with them, & learning a bit more about them (I wasn't aware that GM is now using wideband O2s in stock applications), the $115-$150 price tag is quite a bit easier to swallow.
Thanks again to Navy Blue 01 B4C and alocker.
Old Feb 11, 2009 | 07:37 PM
jfg455's Avatar
do yourself a favor and use the GM ones and not an aftermarket (autozone type) POS sensor. You will be happier in the end and not have to chase some weird drivability issues. JMHO
Old Feb 11, 2009 | 08:11 PM
V8Rumble's Avatar
Cool, thanks. I was planning on getting the AC/Delco brand...
Old Feb 11, 2009 | 09:52 PM
G-Body's Avatar
sawzall wielding director
Wow, I didn`t know that. Glad to hear it though, should really open up the tuning possibilities.
