4.8 info
Old Feb 13, 2009 | 09:19 AM
Tig's Avatar
Tig
Default 4.8 info
I know the old saying " there's no replacement for displacement" but why doesnt anyone use GM 4.8s?
Are the specs different from the 5.3s and up?
Are parts from 5.3 and 6.0 compatible to the 4.8?
Thanks
Old Feb 13, 2009 | 11:46 AM
Andy1's Avatar
The 4.8 uses a shorter stroke crank, different pin height pistons (but same bore), and longer rods. Block and heads are the same as the 5.3 (non L33).
Andy1
Old Feb 13, 2009 | 12:19 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Lol I am still in the air about my motor being a 4.8 or 5.3 but I am hoping its the 4.8 for no reason other than being different.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Feb 13, 2009 | 01:26 PM
Rodder's Avatar
Try a search--some people have used the 4.8L. Generally they cost about the same as a 5.3, get about the same gas mileage than the 5.3, and make less power than the 5.3... so most people go for the 5.3.
Old Feb 13, 2009 | 02:52 PM
Andy1's Avatar
The only way to tell the difference short of a tear down, is to look into the spark plug hole. Flat top piston = 4.8. Dished top = 5.3.
Andy1
Old Feb 15, 2009 | 09:04 AM
dogger's Avatar
l33 5.3 uses 4.8flat top pistons
Old Feb 15, 2009 | 01:35 PM
Kenova's Avatar
... and has an aluminum block.
Ken
Old Feb 16, 2009 | 08:38 AM
BMR Sales2's Avatar
Andy1
I was also told there are casting numbers on the crank that will tell. I have to put my GTO oil pan on it this weekend so I will look then.
__________________
Glenn ***
Sales Tech
813.986.9302
