Whats the best way to put an older 4-spd behind a ls
if you are able to make it happen. I do have an original M-21 in storage, awaiting the right project fwiw.
Use an LS1 flywheel and clutch. If it's a 26 spline disc, you fine. If it's a 10 spline trans, you'll need to get a 10 spline disc that will work with the LS1 pressure plate. I did find an aftermarket 10 spline disc that should work.
You'll need a 168 tooth BBC or SBC bell housing if you dont have one. I got a BBC 621 bell housing from Keisler that's machined with the extra LS mounting holes and it's got an adjustable stud.
You'll need a longer throwout bearing (Oreileys #614037). The short ones will result in poor throwout arm alignment.
And use an LS7 pilot bushing.
That will allow you to use a Muncie withan LS and your manual linkage.
