My Nova's LM7 Transplant
#42
#45
What is "iirc"? This will be my DD; I got PVC coated steel line line since I'm going cheap and I'll be using the least fuel injection hose possible, would that work fine?
#47
#51
Your th350 will work fine, but a few things to note! The Bolt pattern is simular, it will just use five bolts instead of six bolts! it skips the top right bolt! You will also need to get a coversion flexplate! The kits are available from a few different places! They aint to expensive!
#52
Got most of the fuel system plumbed this weekend. Getting the car running next weekend after some parts ship in
#54
My fuel system is a 16-gallon Summit plastic drag cell, Summit inline fuel filter, Summit inline fuel pump, universal FPR from eBay, 5/16" coated steel fuel line from eBay, and various AN fittings. I'm waiting on a pair of fittings then I can buy soft line and finish plumbing
Heres a picture of a bracket I made for the fuel pump/FPR in the trunk:
#55
Dropped the LM7 in this weekend. Ran into alot of problems including a torque converter that didn't line up and Trans Dapt mounts that didn't fit and whose adaptor plates moved the engine at least an inch forward when it was supposed to mount in the stock location, so now I need a new driveshaft.. What a failure of a product. Finished plumbing my fuel system and my friends started on the electrical. It'll be a few more weeks 'til it's ready to run
New 2800-3200 stall torque converter
Right after we got the engine bolted in
What my friend Pat took off of my stock wiring harness
Pat at his "workstation" in Luke's backyard
#57
Thanks for the info. I'm calling Trans Dapt to see if they'll exchange my adaptor plates and take their motor mounts back.
#58
Hey ForcedInduction, who did you go through for adaptor plates and what was the product number? Trans Dapt only makes one for the "factory location" and another 1" forward..
#60
Does anyone know of a good write-up on how to properly adjust the TV cable on my TH350?
