torque arm mount not the same, input needed.
Old Feb 20, 2009 | 10:28 AM
3800RS's Avatar
Default torque arm mount not the same, input needed.
On my v6 tranny the 3 holes on the tailshaft are closer together than the ls1 a4. My torque arm mount i think it is called will not line up. Anything i can do ? Can tailshafts me swapped ? Do i need a ls1 torque arm mount ?
Old Feb 20, 2009 | 12:56 PM
V8Rumble's Avatar
I really don't think that you're going to be happy if you try to use your V6 tranny behind an LS-series engine...
Old Feb 20, 2009 | 01:22 PM
MaxxMitchell's Avatar
What is it that you are doing, a LSx swap in a v-6 car? Might beable to pull the tail shafts off and switch them to make them fit. I thought the TA rubber inserts were the same in all year 4th gens, so why not use the v-6 rubber mounts with the v6 trans?
Old Feb 20, 2009 | 01:54 PM
V8Rumble's Avatar
It sounded (to me) as though he's wanting to use the T-5 trans that came stock behind his 3.8 with an LS-series V8. In my initial response to his post, I wrote that you probably could swap tailshafts - but then saw that it looked like he wanted to use the V6 transmission, & edited my post.
And considering the fact that GM wouldn't even put a T-5 behind the "limp-noodle" TPI 350 engines, you can imagine how long it would last when paired up with an LS...
Old Feb 20, 2009 | 01:56 PM
FlashLCD33's Avatar
^^^ Note.
Old Feb 20, 2009 | 01:58 PM
nprather's Avatar
actuall all 4 TA mounts are different. Auto and stick v-6 and auto and stick v-8
Old Feb 20, 2009 | 02:57 PM
3800RS's Avatar
i will take a picture. I am doing a complete ls1 swap from a 00 into my 97. I guess i really need to find a new ls1 mount.
Old Feb 20, 2009 | 03:16 PM
3800RS's Avatar
here are pics, the v6 bracket on the ls1 tranny, it appears to be a no brainer "NO" and swapping out the tailshafts is a "NO" b/c they are not the same so where can i get this new part ?
Old Feb 21, 2009 | 06:24 PM
RE AND CHERYL's Avatar
You will need a LS1 A4 bracket. The brackets are different for the two v6 and two V8 transmissions.
Re'
Old Feb 21, 2009 | 10:50 PM
3800RS's Avatar
yes thats what i figure.
I have contacted surferd15 on here about the bracket and he refuses to return my calls. I will be paying him a visit shortly if this motor is damaged.
