Converter(un lock) lock up switch question
Old Feb 21, 2009 | 07:21 PM
turbo kid's Avatar
Default Converter(un lock) lock up switch question
I just got my 2004 gto harness back from Speartech and in the instructions he says I need a normally CLOSED brake switch(zero volts when brakes are applyed).My old chevy has a held open switch untill brakes are applyed then the switch closes(and the contact/12volts are made).What do you guys use on the auto trans conversions?Please.Thanks Dan
Old Feb 21, 2009 | 08:58 PM
LS1MCSS's Avatar
Look at the brake pedal mount and see if there are two places for a switch, such as the brake switch. If not, try to find a brake light switch that has two different sets of contacts. Most likely one set is normally open and the other will probably be normally closed. Look at this switch.
http://info.rockauto.com/getimage/ge...tex/1S5240.jpg
Old Feb 21, 2009 | 09:17 PM
turbo kid's Avatar
Thanks I just e mailed them.Dan
Old Feb 22, 2009 | 12:46 AM
lsxyj's Avatar
get u a switch off a late 70s or early 80 gm car or pickup that has cruse control on it that will be the swithc u need
Old Feb 22, 2009 | 08:46 AM
RE AND CHERYL's Avatar
You can also use the brake light switch to trigger a relay. Run your circut through the "normally closed contacts", when the brakes are applied the relay will energize opening the circut.
Re'
