Will this Radiator leak ??
Old Feb 25, 2009 | 05:33 PM
3800RS's Avatar
Default Will this Radiator leak ??
Noticed this when putting in the rad today, one of the horizontal bars seem to be broken. What do you think ?
Old Feb 25, 2009 | 06:02 PM
Shawn MacAnanny's Avatar
Yup it will leak. You could tear some fins away top and bottom with some wire cutters, pinch the area with some pliers, then JB weld over the pinch and it will hold. I fixed a radiator i had like this just fine.
Old Feb 25, 2009 | 07:15 PM
rao's Avatar
rao
Only if you put water in it
Old Feb 25, 2009 | 08:34 PM
3800RS's Avatar
so basically trash eh ?
Old Feb 25, 2009 | 08:57 PM
wbwhiteboy's Avatar
But like he said you can do a temp. fix and it will hold.
Old Feb 26, 2009 | 06:04 AM
You can fix it like i mentioned. It helded for the entire year i had the radiator in my car.
Old Feb 26, 2009 | 06:06 AM
Ryan K's Avatar
Pathological Modifier
Do like he said, except don't use JB weld, heat it up with a torch and then seal it with solder.
Ryan K.
Old Feb 26, 2009 | 06:07 AM
ssick1's Avatar
yea it sure will i just bought another one for my ss
Old Feb 26, 2009 | 08:18 AM
3800RS's Avatar
prob buy a new one. Can i use my v6 radiator for this ls1 swap ? only problem is it only has 1 nipple for the coolant overflow. It does not have the second nipple for the hose that goes to the trottlebody.
Old Feb 26, 2009 | 01:22 PM
Pop N Wood's Avatar
Ryan K.
Does solder work/hold on an aluminum raditor?
Old Feb 26, 2009 | 03:51 PM
V6 radiators are the same from everything i have read.
I'm not sure about the solder and aluminum. I've never soldered aluminum. I know that the JB weld works.
