Completing the LS1 in to LT1 swap, gauge problems now.
Anybody have any suggestions?
I printed out the diagram for the gauges and stuff so I'm going to go start checking on it tonight, but I'm guessing someone else who has done the swap might have ran in to this problem.
Also I had a fuel pump relay problem. When I bypass the relay the car starts and runs fine. I think alldata had some misprints on their pinouts, because i believe I found the right FPR + signal. It's listed as IAC motor in or out on the body harness connector.. which makes no sense. Anyone else run in to that?
How did you wire the fuel pump relay? The LS1 uses a relay under the hood while the LT1 has it behind the driver side kick panel. To make it work you would have had to move the fuel pump relay trigger wire from one of the connectors under the hood to one of the connectors that run into the interior.
Re'
I'm happy to say my first LS1>LT1 swap is on the road and driving. Other than needing a tune (for the MS3), it runs like a champ!
