Need help with tuning msd 6010/carb setup.
That sounds like a good idea. After all, it goes lean at WOT and a little lean at cruising speed. So would I need to up the primary jets a little also.
According to the tech sheet on BG.com it has a pink pump cam in it. Shawn, it this what yours came with?
i wouldn't touch the idle screws 1/4 turn at all if it is already at 13.5:1 at idle, perhaps a 1/16 turn or 1/8 turn but just a little bit will go a long way to reach 14:1 at idle. Next 13.5 cruise is fine, up the secondaries first. See what this does to your WOT a/f ratio. 3 jet sizes on the primaries would be a big jump up. I'd say maybe up 1 more to get it perfect, but for now this would be a clean running engine and wouldn't foul out plugs with a light throttle cruise in that a/f ratio.
I have been told by several people to do away with the PV's. They say they are not needed in a drag car. Is this true? What do they actually do? They say with big cams, it makes it harder to dial in with the power valves opening and closing.
Also, I learned a little bit about over tightening the float screws. I tore up the gaskets and it started leaking. Of course Napa did not have a set of those gaskets so I had to impervize. I got a blank sheet of paper gasket material and used a 7/16" socket as a template and cut it with an exacto knife. Worked fine after cutting a few to get the right size.
Power valves are used most frequently on the primary side of a Holley carburetor. They allow the carburetor to operate with much leaner main circuit jetting for part-throttle fuel economy. Then, when the throttle is slammed open, the power valve adds additional fuel, creating the rich air-fuel ratio needed for WOT operation. Most Holley power valve circuits are designed to add the equivalent of 8 to 10 jet sizes of additional fuel. Holley does offer a power valve block-off part that closes the power valve circuit, but this means the jet size must be increased in order to compensate for the lost power valve circuit fuel. Imagine how bad your fuel mileage would be if you had to add 10 jet sizes to the primary side of your carburetor
hang on to the primary power valve if you're going to be seeing any street driving at all. if you ditched it and jetted up accordingly, you'd be running pig rich everywhere except WOT. its ok without a power valve on the secondary side because the secondaries are usually only open during high load "spirited" driving or WOT when you need the extra fuel
I have not had time to get the car out this week except Monday when I jetted it up. But it runs around 13.5:1 at cruising speed and when I go wot it hits a lean spot then levels out to 12 to 13.5:1. I need to get the laptop hooked up to log the entire fuel curve. Hopefully I can do this next week. Stay tuned guys. Thanks for all your help and advice.
using a p/v in the front even on a race car can help keep the plugs clean on the return road, and in the lanes-you can increase the pvcr also, but better off not if your not fam. with doing it-dealing with .060+ # drills, small changes
i had to go to green pump cams on the LS motors, did some testing with 3 diff carbs, all didnt respond good to the pink cams-the green cams are a little more agressive than the pink, but dont have the duration, but hopefully your into the boosters by then-i moved my p/v closer to my idle vacume, as i had a mild dip into cruise, as the transion to the boosters needed to get fatter
you want your squirters just big enough to do the job-to big and you can drain your pump well to early-your getting pretty big on the jets for a 650, might want to think about dropping the hi sp a/b's down to around .026-.029, should fatten up the circuit, might allow dropping back the jetting-i run a procharger, so some of my tuning is diff., but some of the basic stuff i have found the LS motors want-shame, i just sold an 850 BG
that would have flowed all the fuel you needed, lol
sometimes you have to go back to square one and make one change at a time
if you get to far out-too much info can be really confusing, lol
So I decided to see what it was about. I started with 82frt and 83Rr. It was a little lean at wot so I went to 84frt and 85Rr. I don't have 4 of each jet. It is at 12.5:1 at wot but is very rich at cruising speed around 2500 rpm's like 10:1 to 11:1 and stumbles a little on take off. I got the idle set at 14:1. So I see the importance of the PV. But I'm about to start hitting the track a lot in two weeks. So I was giving this a try.
Today I lowered the frt to 82 and raised the Rr to 87. It leaned out the bottom a little bit like 11:1 to 12:1 and wot is still about the same. Kinda seams like I'm on the right track but that is not squaring up the jets.
I would like to make it work on the PV so the streetability is better. When lowering or raising the PV what does it do?
The last setup on the PV was a 6.5PV with 75frt and 90Rr and it drove fine. Very responsive no hesitation at all. Idled around 13.5 to 14:1, cruising around 2500 rpm's it was around 13.5:1 and wot was about 12.5 to 13:1 with a slight lean spot (14:1)around 4000 rpm's then quickly going to 13:1.
I'm enjoying messin around with different setups to see what it does. I can always go back to square one if I get way out of tune. The box says it came with a 6.5pv 75frt and 83 Rr jets and pink cam with 31 squirters.
The carb was bought for a stock 346ci motor with future plans on going bigger ci later. I also called BG tech and a guy there said it is capable of flowing 840cfm. he said it was plenty big enough for a 383ci.
The timing starts out at 11@0 rpm's then straight to 22 @ 1000 rpm's then staight to 28 by 3000 rpm's. It seams to run fine at that point. Thanks for the advice xpndbl3. You are also right about the pv deal. I just had to try it lol.
What does a larger or smaller pv do in relation to fueling the carb?
I'm thinking about putting a 5.5pv and going back to 75/85 jetting. Another old school drag guy told me he ran a pv on his old dragster and it actually ran better by leaning it out on the big end or I think that is how he put it.
I'm running a bigger carb than you but I don't have any problems with tuning them myself to make up for the part throttle driveability issues that you would run into. At the track the bigger carb will usually be faster than a smaller one.
