Those running aftermarket gauges...
What is the deal with the tach signal on these engines? I have all autometer gauges, all work but the tach so far. First I need to see if the signal is even present in the wire, so how and what am I looking to see in the test?
Autometer says I need part number 9117 which means I have to cut and splice into my coil power supplies..Obviously this is my last resort. I would like to know what everyone did in order to get their tach working properly. BTW I also have EFIlive if that helps matters.
Let me know, thanks.
Sam
Sam
Not sure which engine or harness you are refering too but the ls1 engines have a single tach wire and to run the autometer tach you have to switch it to 4 cyl setting. To my knowledge the resistor is needed if you want to stop the low rpm 600-1000 needle flutter. Mine flutters a little at idle but I'm ok with it. Works fine for normal operation.
That assumes I even have a tach signal in the first place correct? Anyone know how to test this and what I should see?
13 Second Truck Club
i just cranked my car for the first time today and no tach for me and oil pressure guage not working either. is there a port on these motors to put your own oil pressure sending unit
If you have room you can pull the oil sending unit at the back of the intake manifold and replace it with your own sender. You will probably need a metric to SAE adapter, The ECU does not use an oil pressure signal, it is only for the gauge. Other folks have drilled and tapped the fitting down near the oil filter.
Pat
Pat
If you don't have a scope, you should measure something with an AC voltmeter if the signal is there. I'm guessing 3 to 5 volts AC.
Don
I wouldnt have a scope readily available but I do have a hertz scale on my multimeter. Would that give me an accurate reading? Just to make sure, I would connect one lead of my meter to the tach signal wire and the other lead to ground?
I have no signal on the white wire (RPM out) from the PCM. Could I possibly use the Camshaft position sensor or something like that. I assume the PCM uses the cam sensor for RPM, right? Let me know ASAP, Thanks!
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Just an FYI for everyone. I did the 680 pull up resistor and it works perfectly! I went in EFIlive and changed my tach signal parameters to what I needed for an 8 cyl. So no you do not have to change your tach to run in 4 cyl mode if you have tuning software to change the signal.
