Switched Hot to PCM; Amps?
The link to my Fbody wiring diagram is no longer active, hench my questions.
Thanks,
Andy1
BTW, I need to map out some existing circuits and need to know the wire gages. Is there any kind of chart (or link to) that cross references the copper strand bundle diameter with its gage size?
Andy1
For the relay pins 85 and 86 are the control coil. one side is ground and other gets 12 volts when ignition on. Very litle current required. The power circuit part gets battery 12 volts to pin 30 and pin 87 goes to load, pcm in this case. hope this helps.
