fuel line - HARD or FLEX ?
I'm at the point of doing the fuel system on my chevelle and was planning on going flex from the filter/regulator into hard then back to flex into the fuel rail. I would rather go flex all the way -the line would be strapped well and be away from any mechanical or heat areas. what are your thoughts? thanks JOHN
(I thought of a couple more arguments against it while I was typing that - cost, & weight - the braided line probably weighs slightly more than the hard line.
I might have to run more than 12" of flex line with my swap, if I do, I guess I'll have to take my chances...
http://store.summitracing.com/partde...5&autoview=sku
The aluminum line is easy to shape and flare for routing, then use the flex line on the ends. Just don't kink it, use a proper tubing bender.
Pat
Pat
Pat
Actually, come to think of it, I have at least one compression fitting in use by the filter/regulator... Hmmm.
Thanks.
A compression fitting simply squeezes around the outside of hard line.
I'm guessing that kit was made for hard line with compression fittings between the tank and fuel pump, non-pressurized. Then the pressurized fuel between the pump and carb uses the braided line with JIC fittings. The JIC, like an inverted flare is for higher pressure.
Russ
On the braided fuel line, make sure you get the type with a teflon liner. I have known guys who claim the all braided lines will stink up the garage after a time.
BTW, I'm starting my fuel system too, so I need to order stuff.
The Swagelok 3/8" compression fittings are rated for around 4000psi--see the Swagelok datasheet for exact numbers, but I know they were adequate (and approved by the TX Railroad Commission) for 3600psi compressed natural gas lines. These fittings are MUCH more reliable, safer, and easier than flaring the tube.
