fuel line - HARD or FLEX ?
1 Post
Originally Posted by hookemdevils22
Too bad the kit's blue/red. It's $71.95 for black fittings (includes everything in the kit but the tube cutter -- add a 'B' at the end of the fitting PNs). I'm trying to get a hold of someone to ask if I could substitute black fittings for the kit price of $62.95.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Just finished with a rep. He said to call sales and ask for the kit in black. The PN would be SUM-PUMPKIT2B ('B' added to the end of the PN). Although they don't currently have one specified, so you can't find it on their website, they should be able to put it together.
I may do that, although I've got a Walbro 255 pump and 99+ 'Vette regulator that I'm using, so I need to find the adapters to use with those.
I'm using the same setup.
Summit sells the quick disconnects to AN fittings for the fuel rail and regulator inlet.
What do you plan on doing with the regulator fitting outlet line? I know there's a quick disconnect male fitting, but what to join that to?
I used Summit 3/8" aluminum tubing down the frame. From the tank to right by the lower control arm mount I ran -06 Aeroquip socketless, also from the firewall to the engine. Its simple, get a 37* flare tool from Summit, tube nuts and sleeves, and some -06 male to male fittings. Flare the aluminum line, connect the male to male, and connect the -06 hose end. I had my lines ran in about and hour and they look great.
Since I've got a fuel cell with -6AN fittings, I'm planning to go with the following:
*90° hose end attached to braided line --> TFX 40 micron filter --> Walbro 255 pump with Russell 10mm x 1.0 to AN adapters--> Vette FPR --> aluminum hard line to the front --> braided line to the rail
*For the return, it'll be braided line all the way back to another 90° hose end. The FPR will be near the back of the vehicle.
FYI, I ordered the Summit kit. It only comes with AN and a couple flare nut fittings, no compression fittings. I ordered a 37 degree flare tool and some extra nuts and sleeves and I'm going to all hard line except for the braided S/S to the fuel rail.
Sounds like you will have a top notch set up when you are done.
#34
Rich
#35
Rich
#36
I just mapped out the whole run again and made a parts list- 19 fittings including the hard line . I will have about 5` of flex total, I'm not sure what hose to use -Russell proflex stainless or proclassic.
#37
I did the same. I made a CAD drawing (ok, I modified the one by 67RSCamaroVette in MS paint) to show what I did. I've got a fuel cell already, so it was a little easier to begin with. I went with braided line to the FPR, then aluminum to the front, and braided to connect to the fuel rail.
![](http://i105.photobucket.com/albums/m235/hookemdevils22/Reference%20Matl/FUELSYSTEM.jpg)
#38
I'm headed down the Corvette FPR route and want to minimize the number of fittings as well as a cleaner look. I'm running a repo 3/8" stainless hard line to the FPR.
Anyone tried or know of a source who can put the GM EFI fuel pressure "rib" or "kink" onto a stainless hard line so as to eliminate the adapter?
Likewise... any source for the EFI fitting directly to stainless flex line? A vendor could make some money with such a fitting and it shouldn't be that hard to do!
