68 camaro ls1 swap
Old Mar 29, 2009 | 12:24 PM
billyflantos's Avatar
Default 68 camaro ls1 swap
what do i need motor mount adaptors,headers,oil pan and anything else to do this swap it' already got a ls1 6spd with a reg. 23 degree head sm blk in it now...thanks
Old Mar 29, 2009 | 02:44 PM
Stu Cool's Avatar
You will need a high pressure fuel pump and a modified or custom engine harness at least. You will also need a hydaulic clutch set up. Use the search function and read the Stickys at the top of the page. There have been a lot of 1st Gen Camaro swaps so there is plenty of info for you. Just have to look for it.
Pat
Old Mar 29, 2009 | 07:35 PM
i'm going with a carb set up....need to know what headers to use and mounts oil pan etc...
Old Mar 29, 2009 | 09:18 PM
Steve88's Avatar
I went with the Carshop 1" set back mounts so that my turbo 400/gearvendor could stay where they were with the SBC in the car and I am using the sheetmetal Champ pan. You can modify stock F body pan but you lose oil qaunity and some of the baffeling needs to be removed so I was uncomfortable with that and the Champ pan looks great and will work in a road race type car or a drag car. As far as headers--I will let you know in about 2 weeks--I am crossing that bridge now!
Old Mar 29, 2009 | 11:36 PM
68 SS's Avatar
You need to check your T56 if it came out of a car earlier than '98 if it did then you will be better off finding a LS1 T56, if it has a slave mounted on the outside of the bellhousing it will be earlier than '98 and from a LT1 car they are not the same.
I am using a Moroso LS1 pan with remote mount filter and Hooker part# 2288-1 headers with the Hooker mount plates part#12611HKR. You will have to fab your trans mount but not a big deal.
Old Mar 30, 2009 | 12:25 AM
i already have a ls1 6spd in the car now.
Old Mar 30, 2009 | 08:41 AM
fast's Avatar
as stated read the STICKIES at top of this section
Old Mar 30, 2009 | 10:57 AM
i just wanted a quick and easy answer,what headers oil pan and motor mounts to use from somebody that has done it and knows.and got it BIG THANKS TO 68 SS.....
Old Mar 30, 2009 | 07:03 PM
69importkilla's Avatar
billy, what version of the t-56 are you running? is it one of the viper versions with the modified input shaft?
