S10 oilpan problem
Old Apr 3, 2009 | 10:34 PM
sschoen's Avatar
Default S10 oilpan problem
Gentlemen,
I have started a s10 LS1 conversion. I was able to get a engine from a 04 GTO. However, the oilpan has the sump and filter on the left front of the engine. This is a red light/no go for a S10 installation. I did see that a web site (S10V8.com) has the correct pan with sump in rear as normal that looks like it will work great. Does anyone know the P/N or better what vehicals came with this type pan for a junkyard search?
Thanks,
Scott
Old Apr 4, 2009 | 05:17 AM
Jaysz28's Avatar
Active Streak: 30 Days
its a V8 H3 pan
Good luck finding that in a junkyard!
-jason
Old Apr 4, 2009 | 07:40 AM
Jones'n's Avatar
http://www.s10forum.com/forum/f213/l...mation-390967/
Old Apr 4, 2009 | 10:37 AM
topher455's Avatar
I used a ls2 corvette pan but you will have to step the crossmember. On the plus side though it wont hang down past the crossmember.
Old Apr 4, 2009 | 01:33 PM
JohnHF's Avatar
the H3 pan hangs down only about a half inch below the cross member if i remember correctly, its about your only option for a pan that fits with zero modification to the cross member.
http://carshop.carshopinc.com/produc...1227a48b2c3303
Old Apr 4, 2009 | 02:00 PM
LSXHawk's Avatar
We used the H3 pan on the ls7 motor we put in our 98 s-10 blazer. That pan fits perfect.
Old Apr 4, 2009 | 02:13 PM
JohnHF's Avatar
i believe on the blazers it actually sits above the cross member
Old Apr 4, 2009 | 09:15 PM
Jonce's Avatar
I used the H3 oil pan on my first gen '93 S10 and it worked good. You will also need a windage tray and oil pickup tube
Old Apr 4, 2009 | 10:19 PM
grosspeed2k4's Avatar
Has anyone here tried the Moroso pan into a S10/ G-body?
Old Apr 5, 2009 | 09:28 AM
topher455's Avatar
That pan is pretty cool. I wish it was around when I put my brothers truck together. It would have saved me alot of trouble.
Old Apr 5, 2009 | 01:26 PM
Elec87's Avatar
the h3 pan is a great option but you will still have to do a minor notch in the crossmember to make trans removal easier....... on the 2 wheel drive blazers it's cake the pan has zero ground clearance issues and sits above the the crossmember surface due to the raised engine mount pads... On my s-10 we used a f body pan and did some major notching of the frame.
When I worked for carshop I built a 2 wheel drive blazer using a h3 pan and it worked great!
Old Apr 5, 2009 | 06:20 PM
andrew69_04's Avatar
when i did my s10 ls1 swap i used the H3 pan as well. it fit with no mods but it was pretty close to the x-member. i used carshop mounts.
Old Apr 6, 2009 | 02:03 PM
hookemdevils22's Avatar
I've got a truck pan/tray/oil pickup (no dipstick) for sale that I can't use on my nova build. According to the oil pan sticky, it's only slightly taller than the H3 pan. PM me an offer on it if you're interested.
