how to remove connectors
Old Apr 7, 2009 | 04:01 PM
txredxj's Avatar
Default how to remove connectors
so i am starting my wiring and i was wondering how to remove the connectors i dont need. can i just cut the pig tails off at the main harness and make sure they are protected on the end or do i have to trace them all the way out of the harness?
thanks
Old Apr 7, 2009 | 04:12 PM
3800RS's Avatar
prob best to trace them back to the pcm.
Old Apr 7, 2009 | 04:24 PM
rockytopper's Avatar
Cut them off at the connectors protect the ends and be done with it. You can certainly trace them all out and remove them but it isn't necessary as far as function goes.
Old Apr 7, 2009 | 04:42 PM
bczee's Avatar
If you disassemble the red/blue PCM connectors the pin are easly pulled out to make a cleaner harness. Just layout the harness on the engine, connect everything you need or want, unwrap the harness, then just trace it back to the PCM, remove the wire and connectors, then rewrap and put back the PCM connectors. Its a snap !
There are just some tabs on the side of the PCM connectors to unclip the plastic retainer and I think that the bolt will let the connectors come apart.
Old Apr 7, 2009 | 04:47 PM
txredxj's Avatar
not to worried about having a super clean harness so think im just gonna cut them back at the main harness. maybe later on when i clean up the engine bay and tuck wired and move the fuse box i will do it then. just want to get it done and going right now.
thanks
Old Apr 7, 2009 | 07:45 PM
txredxj's Avatar
i know ive seen it but now that i am looking for it i cant find the pin out numbers as they correspond to the ecm connectors. trying to make sense of my c1xx and c2xx plugs and i have wires that dont correspond to other years and dont know how to number the c1 and c2 pugs to ohm them out.
sorry to be a noob but thanks
Old Apr 8, 2009 | 10:03 AM
LS1GMCTruck's Avatar
Default GM Tool?
Is there a tool, for the proper removal of the pins from the computer plugs?
Old Apr 8, 2009 | 10:44 AM
brianjw4's Avatar
I just used a small flat head screw driver to lift the plastic retainer and push the pins out. Pretty easy.
Old Apr 9, 2009 | 01:22 PM
s10-den's Avatar
Just like brianjw4 says,just that easy.I used the end of the wifes bobbypin...take off the little platic ball on the end of it first,workes great for de-pinning computers and wiring harnesses and stuff !...LOL
Old Apr 9, 2009 | 01:33 PM
bumpin_records's Avatar
i been searching and searching for a 2000 harness layout with the connectors tagged. Do anyone have such a layout or can direct me to that layout? Pictures would be wonderful cause i want a clean harness.
