what is needed to make a ls1 harness stand alone
No knock on the guys who build and supply the great aftermarket stuff intended..!!! That is MHO...!!!
Good Luck with your decision..!! DK
What stickys or posts did u use?
I was thinking of moving the wires for the down stream O2s to the Upstream O2s on the PCM connectors so i wouldnt have to lengthen the upstream O2 wires and the connectors/wire colors are the same. Just about everyones using a header that locates the O2 below the firewall and many factory harnesses had the O2s mounted in the manifolds.
Its not hard.
It actually not any harder than setting up a carbed car. Just need to ground the right pins on the PCM, and then different pins need 12v constant and then 12v at ign on and start.. Need to tune out vats and then tap into the tach output to get a tach signal..
Thats all I can remember off my head and I may be forgetting a couple things but its pretty damn easy. I was WAYYYYY overthinking it, I thought car electronics were a lot more complicated than they really are.
The unfortunate part of this is that I'm quite a ways from actually having my conversion ready for its first start up, so I may try building an engine stand I could run the motor on by itself to prove the harness works. Still this is a several months down the road unfortunately.
https://ls1tech.com/forums/conversio...o-lt1-car.html
i am in the same boat ,I really would like to get a harness from speartech or painless, Etc
but i just cant see spending the coin on it. so i am going to modify it myself.
my swap is from a 2004 gto w/t56 i think the most useful tool is the alldata website if you have the diagrams you can identify all the wires and and all the components ( fuel pump relay , starter relay, cooling fan realys) and the correct wires for Clustr/gauges.
i will start a new thread with that progress however if we keep this post going maybe some folks who have done their own harness will chime it .
I had wanted to do a step by step write-up for it, but haven`t really had the time and I haven`t figured out how to put it together because all the conversions are so individualized. Heck when I did my El camino I didn`t even have actual wiring diagrams for the truck
, I had a ohm meter to trace the wires out and a set of mostly complete pinouts for the PCM, then I looked at the f-body diagrams to figure out what that circuit didFor pricing you would have to check their websites, or the sponsors here. I know Wait4meperformance sells EFILive and I`m not sure if HPT is sold by some of the sponsors or just direct through their website (I bought it direct through the website). HPT was right around $500 when I bought it a couple years ago and IIRC EFILive7 was a hundred or 2 more expensive at that time.
I'll also be making my harness.
