Can you use a T56 6-Spd Trans from a ’93 LT1 on a LSX Engine?
I purchased a bellhousing from Quicktime that will allow me to my LT1 T56 to my LQ4 engine. I will need to use the LT1 clutch and pressure plate and a LS flywheel. I'm not sure if the LT1 pressure plate will bolt up to the LS flywheel. I will let you know how this works out.
