How important is the trans crossmember??
Here is an example of how the trans sits in between the frame and where the crossmember has ended up.
Comments please.
You want the angle of your driveline to match the angle of the pinion in the rear end, but in reality, a lot of people don't even bother to check it unless they are having a driveshaft vibration problem.
Ok this is something that someone else mentioned to me as well.
Cheers.
general update: I found my mounting plates and they are they type that locate an LS1 engine into a factory location in a car setup originally with a sbc so I am Figuring that if i got a transmission x-member it would be one that would convert a TH350 to a 4L60E using factory mount locations.
I might even build it myself if it comes down to it.
Mine is right in the middle.. here is a paint rendition from memory.
So heres my plan.. move the cross member back to original holes. then cut it on the inside edge of the exhaust humps then fab a center section that goes down and back with a mounting plate in the center.
