2007 6.0 liter wiring help
So far I have decided to eliminate.let me know if i am forgetting something. I have searched for info but i cant find what i am looking for. I wanted to make sure the pcm does not need these inputs.thanks
Evap
Downstream o2 sensors
oil level switch
engine oil pressurefuel tank pressue evap
fuel level signal pin 54 in green connector
But these are the general ones (some already listed above):
- AC
- EGR
- AIR Pump
- PCV
- EVAP
- Oil Level
- Fuel Tank Level/pressure
- Oil pressure sensor (can just connect your Car/Truck sensor up), most later years PCM's don't require it for anything. You can use it for the fuel pump relay if you want or just let the PCM do the fuel relay control. I use the location for my Chevelles idiot light.
and of Course .. VATS !
It come down to adding the required wires to the pins for the Hot 12+v battery, hot 12+ ign/switched where needed, the pink and orange wire. Then wire up the pins for the Fuel relay.
Otional but suggested: ODBII/Serial Data, MIL/Check engine light.
The Van should have a fan on the pump/pulley, so no relay wire is needed, unless your going to dump the fan for a e-fan setup.
Suggested you also use relay and fuse on all the required hot wires.
Then once you have converted it to standalone, then open up the rest of the harness, connect what is needed (coils, sensors, etc) or required and strip out what you don't want (EGR, Air, EVAP, etc) and then rewrap the harness. you should be able to remove the wire all the way to the PCM connector (it comes apart and the wire/pin will just slide out)
That is the short story...
I also need to make sure pin 39 y/bk does not need to be there. I am installing the current performance fuse and relay panel too. It should be done in a couple of days when I get time to work on it.
