Ack! Electric problem (blowing alternators)
Old May 2, 2009 | 07:30 PM
tracar91's Avatar
Default Ack! Electric problem (blowing alternators)
I finished my LS1 swap into a 1991 Z28 last summer, drove it all year, then put it up for the winter.
When My dad got it out this spring to take to a car show while I was out of town, he told me the alternator wasn't charging. Sure enough, the 80 amp fuse I installed in the alternator charge wire (battery is in the rear) had blown. I replaced the fuse to see what was what and I promtly blew the alternator. Replaced the alternator, traced all the power wires and didn't find anything obvious. Fired it up again today and it popped the fuse in the first 10 seconds.
I am not a wiring guy, so I have no idea how to track this issue down. Any suggestions?
Thanks in advance.
Old May 2, 2009 | 10:54 PM
Jaysz28's Avatar
Active Streak: 30 Days
check your grounds
-jason
Old May 2, 2009 | 11:08 PM
tracar91's Avatar
Default Grounds
I currently have two grounds from the engine to the body, and one from the battery to the body. What should I be looking for?
Old May 2, 2009 | 11:28 PM
Rodder's Avatar
Let me get this straight... you're putting an 80Amp fuse on a 102Amp (Camaro), 110Amp (earlier Vette), 140Amp (GTO), 145Amp (Later Corvette), or 150Amp (Later Corvette Convt) alternator... and you can't figure out why you are blowing fuses?
Old May 3, 2009 | 09:58 AM
tracar91's Avatar
I'm not just blowing fuses, I'm also blowing alternators.
Old May 3, 2009 | 11:07 AM
Pop N Wood's Avatar
No easy answers on this sort of thing. You have a short somewhere and need to find it.
Start with the obvious. Look over all your wiring for anything unusual. See if any wires have worn through and are shorting to each other or sheet metal somewhere. Look for any signs of arcing or overheating. Pay particular attention to anyplace where the wires are routed through sheet metal holes.
Beyond that get an ohm meter and start checking for short. I would also bring your battery in to be tested. Those can short out also.
Good luck
Old May 3, 2009 | 05:14 PM
Shawn MacAnanny's Avatar
Do you have the 480ohm resister installed in the alternator exciter wire? This will destroy ls1 alternators
Old May 3, 2009 | 10:53 PM
Syclone354's Avatar
You dont need the resistor on the Camaro alt, just the vette and truck alt to make it charge.
Old May 4, 2009 | 12:52 AM
Thats not true. Camaro alternator needs just 1 wire with the resistor, vetter and truck alternator needs two wires.
Old May 4, 2009 | 05:22 AM
Pop N Wood's Avatar
If he has the alternator wired through the PCM then the resistor doesn't matter.
Besides, he said he drove it all last year. Seems like it would have fried the alternator back then.
Old May 4, 2009 | 05:32 AM
Oh yeah, duh, i forgo there are people who do efi swap haha.
Old May 4, 2009 | 07:55 AM
tracar91's Avatar
No I didn't add a resistor, but it is a fuel injected swap (using the original pcm for the engine).
I believe I have to have some kind of short, but I have not found it by tracing the wires. Is there a procedure to check for shorts? I am certainly not an electrical guy, so speak slowly and use small words
Old May 4, 2009 | 09:04 AM
crainholio's Avatar
Gotta get this fixed in time for the National F-Body Event dude!!
Here's a start:
1.) Disconnect that big batt-postive wire from the battery, and from the alternator. Don't wiggle the cable or otherwise disturb its position...if it's shorted, you want it to stay that way.
2.) Whip out your Ohm meter and probe the cable at the alternator end, with the meter's other probe (doesn't matter pos or neg for this test) probing a good ground.
3.) Report back with the meter reading. Should be no continuity whatsoever. Anything else indicates a short. I expect you'll get infinity on your meter, which indicates a dead short to ground.
Report back with your findings and we'll go from there.
Old May 4, 2009 | 11:55 AM
miro's Avatar
Also check the continuity of the small wire running from the alternator to the PCM. If this has come loose/broken somewhere, alternator might be putting out way too much current.
Old May 4, 2009 | 01:19 PM
crainholio's Avatar
I didn't know that, good point. I figured if that wire was open the alt wouldn't charge at all, similar to older applications.
Old May 4, 2009 | 11:38 PM
Rodder's Avatar
I'd say the fuse blew first, and then the alternator fried. You can't remove the battery wire on a running internally regulated alternator without damaging it.
Old May 5, 2009 | 02:26 PM
tracar91's Avatar
Ok, disconnected the battery, connected the end of the big alt wire (at the blown fuse) to the body ground strap (where I bolted the negative cable to the body) reading at the 200k setting was 85.9. Not sure what this tells me though. I also did the same thing at the front touching the post on the alternator and several places, read 85.9 everywhere grounded to the body.
Re-connected the battery cable, disconnected the small wire to the alt, checked for voltage with the motor running. Read 25 millivolts.
Old May 5, 2009 | 02:43 PM
tracar91's Avatar
Default another update
I also hooked the alt back up and checked for voltage in the alt wire while running, nothing. Looks like another blown alternator. Crap.
Old May 6, 2009 | 08:43 AM
crainholio's Avatar
The premise someone posted previously makes sense...the fuse is undersize for the application, and when it blows it causes the voltage regulator in the alt to fail.
1.) The batt is in need of a nice slow recharge, having set all Winter without a battery tender on it. I like 2 amp charging rate for Optima gel batts. Don't overcharge it, just get it back up to a full charge.
2.) The fuse may not be sized properly. The battery at it's low charge state is likely pulling more current from the alt than the 80a fuse can take. Look up the max fuse size for the guage of wire you're running back to the batt, and install that. As stated above, the alt is rated at least 110a peak output so you'll need at least a 110a fuse.
3.) The voltage regulator in your new alt is toast. Swap in a replacement alt after solving #1 and 2 above.
Old May 6, 2009 | 10:38 AM
tracar91's Avatar
So in summary, I can eliminate the fuse (make is a solid wire from alt to battery), trickle charge the battery and replace the alternator (thank god for lifetime warranty ) and things should be all good?
