72 Chevelle LY6 Cam Only Dyno #'s
Old 05-04-2009, 09:07 PM
alocker's Avatar
Default 72 Chevelle LY6 Cam Only Dyno #'s
I got the car dyno tuned at Speed Inc. last month and wanted to share the results. This was by no means a cheap build, but I was cost conscious and was patient to get the best deals possible. The original plan was to use and LS2 out of a TBSS, but a classifieds scammer scrapped that idea. I settled on a 2007 LY6 out of a rear ended 2500HD.
25k Mile LY6 with stock 823 heads.
SI5 cam (231/237 .589 .595 112)
Patriot Gold's
L76 intake and rail
LS7 Injectors
LS2 Throttle body
Edelbrock 1 7/8" Headers
TKO 600
12 Bolt 3.31 Posi
Old 05-04-2009, 10:13 PM
ryanvv355's Avatar
Sweet car and impressive numbers! Good job
Old 05-05-2009, 09:41 AM
TOOSLO5's Avatar
Nice ride and a nice clean install! Kind of partial to any A body myself.
Old 05-05-2009, 11:36 AM
13 Second Truck Club
726.0chevelle's Avatar
very nice car man
Old 06-06-2009, 12:01 AM
alocker's Avatar
Went up to Da Grove tonight and made some passes. 38 PSI in the Sumitomos.
Best run
60' 2.248
1/4 12.937
MPH 112.62
Best MPH 113.76
Old 06-06-2009, 12:48 AM
BES Stroked Nova's Avatar
specs on the cam??
Just wondering, cause I had a 6.0L(LY6 crank rods and pistons in a 06 GMPP block) with unported L92's, MS4 cam and a GMPP unported intake, my car dynoed 458 to the wheels be 4.10 gears...
now with mild port L92's, custom 242/246 cam, same short block I am making 500+ at the tire...
Just throwing some Idea's out there for future plans!! nice clean build by the way!!
Old 06-06-2009, 06:11 AM
alocker's Avatar
SI5 Cam (231/237)
All it has are springs. Everything else is stock.
Old 06-06-2009, 04:00 PM
NemeSS's Avatar
very impressive!
Old 10-13-2009, 02:11 PM
bfrank79's Avatar
hey what brand cam is that you are running, is it streetable?
Old 10-13-2009, 03:42 PM
alocker's Avatar
Speed Inc 5 cam or Comp 231/237. Yes its streetable, but i probably would have gone a notch smaller.
Old 10-13-2009, 09:19 PM
crosstraining's Avatar
Sweet build. I agree with tooslo5 it is very clean. Good numbers
Old 10-14-2009, 03:36 PM
hotrodscrap's Avatar
Nice car and numbers!
-SS
Old 10-14-2009, 03:50 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,156 Likes on 752 Posts
Nice, how about the lifters, do they need to be swapped out for LS2's?
Old 10-14-2009, 04:30 PM
malibu9in's Avatar
Nice ride...looks factory. lots o power too!
Old 10-14-2009, 05:52 PM
alocker's Avatar
thanks for the compliments!
Nope, stock lifters. This is a VVT not an AFM motor. VVT uses regular lifters and valley cover. I did change to longer CC pushrods though.
Old 04-16-2010, 06:29 PM
twitchtwice's Avatar
Are you using the factory radiator? If so, what hoses are you running? Are you using the Kwik swap bracket for the alternator?
I am thinking about doing a carbed ly6 mated to a t56 in my 69 Camaro and I am making sure that I have all the pieces before starting.
Thanks,
Chris
Old 04-16-2010, 07:50 PM
alocker's Avatar
Thanks,
Chris
Yes, factory brass 2 core with 1995 Ford Windstar twin cooling fans. The hoses are autozone pieces spliced with a reducer bushing on top. The bottom is cut to fit. I just bent a hanger and browsed the hose rack till I found what fit.
the alt bracket is stock LY6. Pretty sure it wont work on an F-body as I have about 1/2 inch clearance on my A-body.
Hope this helps.
Old 04-17-2010, 09:26 AM
Jimbo1367's Avatar
Best run
60' 2.248
1/4 12.937
MPH 112.62
Best MPH 113.76
So how does that think pull? You a fan of the VVT then? Did the cam make alot of difference in pull.?
thanks,
Jim
Old 04-17-2010, 09:41 AM
alocker's Avatar
I removed the VVT stuff since it was right before you could get the phaser mod kits.
It still pulls great. Mid and high end is fantastic for such a mild build.
I had it re-tuned by Mike at Straightline and it put down 420/405 on a Mustang Dyno.
Old 04-18-2010, 02:42 AM
6D9
6D9's Avatar
Sweet build man. I was thinking about doing the same swap for my 69 camaro. I thought with 420RWHP it would have a bit more trap speed though. How many passes did you get to make??? Trying to justify the swap cause it looks like my current combo 400sbc makes similar power. How is the fuel mileage??
Quick Reply: 72 Chevelle LY6 Cam Only Dyno #'s
