How close is too close?
Old May 6, 2009 | 03:58 PM
fast400's Avatar
Default How close is too close?
I'm nearing the end of the tunnel on my 69 firebird conversion, and there are a few loose ends that I need to feel comfortable about. The main one is the fuel system. I used russell aluminum line from front to back. Near the engine bay there is one area where the fuel line is about 5-6" away from the headers, and in the rear over the axle, the exhaust gets about 2-3" away at one spot.
Question is...will this cause problems? Or is that enough distance?
Old May 6, 2009 | 05:16 PM
bczee's Avatar
It should be alriight, but if your that concerned or it does become a problem, I'd wrap it in some of the Cool It/Thermo-Tec Heat Shield or Wrap.. or even build a aluminum shield.
Old May 6, 2009 | 07:10 PM
Pop N Wood's Avatar
Exhaust cools as it flows back. So you don't need as much clearance in the rear.
A sheild or some wrap as suggested couldn't hurt.
Old May 6, 2009 | 08:01 PM
jomomma's Avatar
x3 on a shield if your worried. i think thats plenty of clearance.
Old May 6, 2009 | 08:23 PM
Jonce's Avatar
You should be fine. I ran Russell braided hose and 6AN fittings from the tank to the fuel rail on my S10. It's about 2-3" just down from the exhaust header collector and never had a problem. I just made sure I fastened with zip ties or the like so it won't move. I found some fasteners from Ace Hardware that you can bolt to the frame (or where ever) and there is a eyelet tab on it for a zip tie to go through. I used that to secure my fuel line next to the exhaust.
Old May 6, 2009 | 11:28 PM
screaminChick-n's Avatar
X 4 on the heat sheild. get some thin alum sheets from HD and snips and go to town
Old May 9, 2009 | 03:51 PM
fast400's Avatar
Thanks guys! I was thinking of putting a cool-it around that area.
