LS? Zx2
Old May 16, 2009 | 12:45 AM
LS2-Zx2's Avatar
Default LS? Zx2
What kinda of setup should i use to LSx series my Zx2 (Ford). I know this is sacrilege to put a badass Chevy engine into a Ford but hey i think it sounds like fun. I fairly sure i wanna do a RWD setup so i'm gonna need to make a driveshaft tunnel. I know you can make a cheap 5.3 go like hell cheap but would it be easier to get a whole LS2 vette chassis and lay the ZX2 doghouse on it or what?
In a nutshell the questions are:
1. Keep it FWD or make it RWD?
2. What liter motor?
Old May 16, 2009 | 09:27 AM
LS2-Zx2's Avatar
If i got a whole package like this it might be the easiest way but its kind of expensive. For what it is its reasonable but its still costly
$10k
Old May 16, 2009 | 01:00 PM
topher455's Avatar
There was a guy over on www.theturboforums.com that was putting a 32v cobra drivetrain in one. It was in the builds section.
Old May 16, 2009 | 03:20 PM
supernova1972's Avatar
There isnt gonna be a cheap way to do this at all.
Old May 17, 2009 | 12:29 AM
LS2-Zx2's Avatar
Rather use a LS2 like pictured above. although 32v Terminators are badass just the motor is 10k whereas the whole drivetrain/chassis (above) is there for 10k
Old May 18, 2009 | 08:08 AM
topher455's Avatar
You misunderstood. I meant you could look at his build to get an idea how you may or may not want to do your build.
Old May 18, 2009 | 02:13 PM
jfg455's Avatar
Supposedly there was a kit from Kugal performance products that made a crate 5.0 and a T5 blot into the chassis without any floor modifications. They did however switch the knuckles to a front steer set up with the rack up front. That being said, an LSX style motor and a T5 should slide into the car with =out cutting the tunnel or front floor. The took the bacl off the stock cradle and put mounts onto the sides fro the motor. They also use an 8.8 from a mustang with front wheel drive offset rims in the back without cutting the tubes down. You will have to relocate the fuel tank to behind the axle though. Do a search in car craft or hot rod for a V8 focus and you will find it.
look here for parts lists http://www.kugelkomponents.com/focus/focus.php
Old May 19, 2009 | 11:06 AM
LS2-Zx2's Avatar
ty to everyone. i appreciate any advice or help thats constructive =]
the "easiest" route would prolly be how the CiVette did it. Ive been thinking that would be how id do it and i checked his build and it gave me hope
Old May 19, 2009 | 11:38 AM
digitalsolo's Avatar
I'm guessing you have some good fab skills?
If not, this will be EXPENSIVE. Even with skills, I'd expect 15-20k is not way out of line in costs.
Would be pretty neat if completed though. Have you every done any projects of this magnitude before?
Old May 19, 2009 | 12:08 PM
topher455's Avatar
Yes this swap will definitely be expensive either way. But if or when you finish you will have a one of a kind vehicle on your hands.
Old May 19, 2009 | 02:03 PM
LS2-Zx2's Avatar
I have good fab skill and lots of friends with great fab skills (drag racers, Mini truckers, etc). im good with metal and good with electronics and i wanna tackle a big project but im still trying to get everything figured out b4 i start buying. first step is searching junk yards and trying to find a wrecked LS2 vette. I would settle for a wrecked LS2 GTO or even a LS1 vette if cheap enough and pretty much take everything from the donor and fab it on the Zx2.
Old May 20, 2009 | 12:33 PM
TTLS1GP's Avatar
I did my RWD swap in the grand prix for $3k including the price of the car. I got some key parts for free or already had them but it's by no means 20k. If you don't to a whole lot of "while I'm here" stuff it can be done on a decent budget.
Old May 20, 2009 | 12:47 PM
rotor vs. piston's Avatar
dp...
Pics of Grand Prix
How far are you on the RX7?
Old May 21, 2009 | 09:55 AM
topher455's Avatar
Yes pics of the GP please.
Damn the "while Im there" stuff it gets me every time LOL
Old May 23, 2009 | 11:11 PM
LS2-Zx2's Avatar
86 Regal: Iron block LS2, T-56, Custom cam, 8.8 Diff, supporting mods, and a Custom 700cfm Fuel Metering Device (shhh its a carb)
i didnt know they had iron block LS2's unless you did alot of parts changing?
Old Jul 2, 2009 | 11:17 AM
LS2-Zx2's Avatar
I might be doing this project sooner than expected seeing as how i think my little 4 banger puked. have to pull some parts off and investigate. If its dead it may be time to head to the junk yard and find a wrecked 6.0 GTO lol
Old Jul 4, 2009 | 07:32 AM
LS2-Zx2's Avatar
NVM =[ i need to get a dd before i get to crazy. might just scrap this project and get a 99ish f-body w/ a LS1
