Basic ECM reprogram, what to ask for?
Old May 20, 2009 | 06:37 AM
rotor vs. piston's Avatar
Default Basic ECM reprogram, what to ask for?
The seller of my engine also offered to reprogram the ECM. I bought an '04 GTO drive line w/ 6m. This will be going in a '89 truck and want the minimum I need to have a drivable vehicle.
The basics are deleting VATS, the after cat' o2 sensors, fuel take evap, getting it programmed for my gear ratio and tire size. What else should I be asking for? Is there a good list of "if you do this, it will run like it should" to the ECM?
Thanks
Old May 20, 2009 | 10:01 AM
bczee's Avatar
What else are you NOT using from the new engine for your swap ?..ie.. EGR, AIR, AC? then have him disable those.
E-Fans temp could be set lower to match a lower T-Stat.
If he has done Tunes before, He might have some basic tune's that would change/modify the Timing and Fuel table for a basic performance Tune, but a dyno tune would be the best in the end.
Old May 20, 2009 | 11:58 AM
Would gear ratio and tire size programming be something I would need to worry w/ if I'm using a 6m?
Old May 20, 2009 | 12:15 PM
mynamewasloki's Avatar
for speedo and tech purposes, yes. i'm sure there are more reasons too that someone will add in
Old May 20, 2009 | 12:31 PM
Hmm, planned to pull the signal straight from the VSS to my VDO speedo... if the ECM doesn't have a speed limiter what other use would it have for knowing the correct speed?
Old May 20, 2009 | 06:15 PM
poconojoe's Avatar
Yes you should have the correct calibration for your VSS, the pcm uses it for a lot of things including turning off you fans, when you reach a certain speed.
Old May 20, 2009 | 08:17 PM
Will one of the programmers like EFI-live or LS1edit do what the "programmers" do when you send your ecm away?
The guy said $250 and I've seen people say ~$90 for them to do it. What are they using to delete VATs, emissions and setting fan activation temps?
Old May 21, 2009 | 08:44 PM
jomomma's Avatar
yes, they do. if you can find a local tuner that tunes with a program like hptuners or the others you listed, then they will be able to do anything you want to your pcm.
