Miata differential upgrade options for LS1..
Old May 20, 2009 | 07:01 PM
EspaceF1Fan's Avatar
Default Miata differential upgrade options for LS1..
Besides the 8.8 setup everyone is using, are there some factory options for differentials? Will RX7 or RX8 diffs work? Do they bolt in? I'm just curious what kind of options I might have. I'm probably about to trade my Msutang for a Miata, and a good friend of mine just gave me a pile of LS1 parts, so I obviously have only one choice....SWAP TIME!!!!
Old May 20, 2009 | 08:23 PM
rotor vs. piston's Avatar
Racing Beat may have some options for you or flying miata.
http://www.racingbeat.com/FRmiatamain.htm
Old May 20, 2009 | 08:51 PM
sm2dan's Avatar
I'm running the Getrag stage 1 from Flyin Miata
http://flyinmiata.com/index.php?dept...002%20%208.8S1
using a 3.42 LSD from a 2006 Cadillac CTS
d
Old May 20, 2009 | 09:11 PM
R-Bo's Avatar
Was just about to say call Bill at Flyin' Miata...
Old May 20, 2009 | 09:49 PM
Thanks for the info guys!!!
Old Aug 1, 2009 | 11:34 PM
Ls1Mx-5's Avatar
The best route is the rx7 turboII LSD. Not only does it bolt into the stock location, but has mounting points for a torque arm
Old Aug 2, 2009 | 10:31 AM
sciff5's Avatar
Where are the mounts on a t2 diff for a torque arm?
You might be thinking of an FD diff which came with a torque arm, turbo 2 diffs in the FCs didnt have torque arms
Old Aug 2, 2009 | 02:06 PM
Ls1Mx-5's Avatar
This is what I have. 86-88 (I think) 'TurboII LSD'.
There are three mounting points for a torque arm whether rx7s originally had them or not.
Old Aug 2, 2009 | 03:22 PM
sciff5's Avatar
It might be a t2 diff but those 3 bolts arent for a torque arm. THey are what the front diff mount connects to.
You could use the bolts with a torque arm though prob, as it works similarly
Old Aug 2, 2009 | 07:47 PM
Ls1Mx-5's Avatar
Thanks for the picture, that helps allot.
Old Aug 2, 2009 | 10:51 PM
Project GatTagO's Avatar
TII aluminum housing + 1988 929 carrier with 3.73 gears + TII diff = direct bolt in factory rear end with limited slip and 3.73 gears.
http://picasaweb.google.com/alaivins...78269943330050
Andrew
Old Aug 3, 2009 | 09:10 AM
Dan_W's Avatar
Are there any gear sets available for these (numarically lower) in the 2.70-3.30 range?
Who has one in their car?
Old Aug 3, 2009 | 09:43 AM
sciff5's Avatar
Andrew
So why arent more people running this setup in the Rx7s?
Looks like the issue would be that the diff is shorter thus the rear flange will hit the rear subframe.
Old Aug 3, 2009 | 01:03 PM
Exactly. You are also faced with the other weak points, such as the stock stub axles and CV axles. However, I feel that in a light weight Miata, those weak links would not be so apparent. I think that a 929 carrier with the 3.73 gear will live a happy life in a Miata, mostly because Miatas are so traction limited. Wheel hop will also need to be controlled.
Andrew
Old Aug 3, 2009 | 01:04 PM
The only other ring and pinion that is available for TII rears is a 4.33.
Who has what exactly, in a car?
Andrew
Old Aug 3, 2009 | 01:11 PM
Ls1Mx-5's Avatar
Andrew
Mine is going to be mounted in this week. It has 4.10 gears
Old Aug 4, 2009 | 08:26 AM
Dan_W's Avatar
Who has this rear end in thier miata.
Andrew
Old Aug 4, 2009 | 09:00 AM
Ls1Mx-5's Avatar
The guy who said these only come with 4.33 gearing is wrong. We tested the ratio of mine and it was 4.10
Old Aug 4, 2009 | 08:45 PM
NMJ87T2's Avatar
Foreign models had the 4.33 option. I can give you a Mazda part number if you are interested. Well here is a link for some info for everyone.
http://www.mazdamotorsports.com/pdfs...Drivetrain.pdf
Old Aug 4, 2009 | 10:29 PM
Dan_W's Avatar
Does anyone make other gear ratios for it... aftermarket, etc?
