Mazda RX-8 LS-1 swap
Old 06-22-2009, 09:05 PM
  #41
Project GatTagO's Avatar
Received 1,443 Likes on 911 Posts
Originally Posted by Mark S
Andrew,
I'll defer to you concerning questions on Mazda diffs, since most of what I know I learned from reading posts from you and Ray, but I believe the carrier shims are the same on the FD and the 8... Would that indicate the -8 runs an 8" ring gear?
http://www.mazdatrix.com/8-Diff.htm
Edit: Kaaz lists the same part #s for the FC Turbo, FD and RX8...
I could definitely be wrong on this. If it is an 8" gear then there is hope that it will work OK as long as the car is not drag raced with sticky tires.
Andrew
Old 06-25-2009, 09:17 AM
  #42
owen v8litew8's Avatar
saw this thread on rx8club about the diff gears being shared with the S2000 and that opens up some choices for a lower geared ring & pinion but I dunno about how strong the options are...
http://www.rx8club.com/showthread.php?t=77054
Old 06-25-2009, 03:02 PM
  #43
Restricted User
speeddemon651's Avatar
pretty awesome so far
Old 07-15-2009, 01:01 PM
  #44
delphicwhisky's Avatar
Hello.
I might possibly get this RX8 that has been swapped with a Toyota engine recently but the owner says the cluster isn't working. What exactly is the solution? How can I get the cluster to work if I get the car? Really interested.
Regards.
Old 08-31-2009, 10:51 AM
  #45
Motorstilling's Avatar
Here is a new video from last weekend.
The car ran 12.831@110.57, on stock motor.
We still need to get the cluster to work.
http://www.youtube.com/watch?v=H8nbqUKUTC4
Old 08-31-2009, 01:49 PM
  #46
themonkeyman89's Avatar
Fan-freaking-tastic. Love it. THe rx8 is a beautiful-handling car, just needs more torque than a rotary can give. Looks great!
Old 09-17-2009, 05:07 PM
  #47
finiata's Avatar
Have you gotton anywhere with the can bus interface? Doing an NC miata, so it would be just about the same.
Old 09-20-2009, 09:20 AM
  #48
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Interesting. I just saw a local dealership has an 04 RX8 for sale with no engine in it.
Old 10-03-2009, 09:59 PM
  #49
shaggsm3ls1's Avatar
I just fired up my M3/LS1 conversion tonight, and I'm trying to get my friend to do an LS swap in his 04 8.
MotorStilling, how have the mounts been holding up? If they are doing the job, then you should seriously consider have them machined 10-20 at a time and selling them. The hardest part is the mounts, aside from the wiring, but if there were mounts available for purchase then alot more people would seriously consider doing this swap
Old 10-26-2009, 03:38 PM
  #50
06 6.0 GTO's Avatar
This is beyond awesome. Now the RX8 has it all. PERFECT
Old 10-26-2009, 05:59 PM
  #51
-Q-
-Q-'s Avatar
If you haven't seen this....it's hilarious. Hitler reacts to the Rotards...
http://www.youtube.com/watch?v=zxsY4lEGRBI
Old 01-11-2010, 10:27 PM
  #52
Civette's Avatar
i know how to make your gauges work without an interface.....would you like to know lol
Old 01-12-2010, 05:19 PM
  #53
b005td's Avatar
more info is needed here
Old 01-12-2010, 06:53 PM
  #54
jonathan_ed3's Avatar
Are those 300zx wheels on the back end of your rx8? Out of curiousity, what did that Mustang run?
Very nice car/swap you have there!!!!
Old 01-16-2010, 10:11 PM
  #55
Civette's Avatar
you just have to keep your stock computer in the car still.....its easier and cheaper.....but you have to find somewhere to keep the computer.....there is a lot of ways to do it....but the cleanest way is....installing the sensors you want to work into the motor and just wiring them to the stock computer yourself (or keep your stock harness in the car and cut out what you dont need, this way gets cluttered)....my wrx like this allowed everything including things like abs to still work.
Its actually very easy to do......
i wired the T-56 VSS to the input of the wrx computer and it reads perfect.
wired the tach signal from the camaro computer to the tach signal into the wrx computer.....reads perfect
i drilled out the open spot on the top of my waterpump (not the proper location though) and put my wrx coolant temp sensor in and wired it to the wrx computer
tee'ed off the oil pressure sensor and put the subaru oil pressure switch for the low pressure light and wired it to the wrx computer..
the fuel level is normal but does run through the computer....didnt do anything to it.
Old 01-16-2010, 10:15 PM
  #56
06 6.0 GTO's Avatar
Any new news on when a kit will be available? if there will be one available
Old 01-20-2010, 10:37 PM
  #57
Civette's Avatar
ill be doing one of these also....i will be selling a bolt in subframe kit....and will probably be half as much as hinson will be selling there's......i will have my wrx subframes ready in about 3 months
Old 01-24-2010, 02:37 PM
  #58
93Polo's Avatar
Will you be selling a harness to keep the guages working?
Old 01-24-2010, 06:37 PM
  #59
Civette's Avatar
you dont need a harness....ill just provide a diagram on what to do
Old 01-24-2010, 10:08 PM
  #60
stock240sx's Avatar
awesome swap!!!!!!
Quick Reply: Mazda RX-8 LS-1 swap
