93 LT1 to LS1 Wiring Harness Conversion How To
Old Jun 11, 2016 | 08:37 PM
Jose93z28's Avatar
Originally Posted by B_Mack15
From what i have been reading this doesnt seem bad at all. I do have 2 questions though. Will a stock 5.3 be able to run on a 98 ecu and did you have to strip your harness all the way down or did you just locate the wires and try to move them individually?
A stock 5.3, ls1 etc will run on a 98 ecu if its matched to the same year harness, I believe 98 is the only offset ecm as they were the first year, if you can go 99 or newer on both harness and ecm, also all you do is locate the wires and move then individually, I did my own on my 93 z28 with a 2001 harness and 99 ecm just by reading and printing the merv's guide a couple years back.
