Filter/regulator
Last I got mine from Speedway as a part of a kit they sell that also comes with an adapters, it cost me about $65.
I prefer stock rails because the price is right - free with the engine or pretty cheap from someone doing an upgrade.
If I remember right, the 5.3 injectors are longer, but the Flex Fuel 5.3s have injectors that are the same length as LS1 and LS6. Don't quote me for sure on that though. I switched over to an LS2 right after I was fiddling around with my 5.3 (sold it) so I am not an expert.
You can buy the 5/16 blockoff connectors fairly cheap.
With one -6AN Push lock fittings, http://www.summitracing.com/parts/su...01-b/overview/
Or the Dorman 800-155 - http://amzn.com/B000CIR1PW
What I ended up doing is going old skool, fire up the lathe and making a fitting. One line is made up from the pump to the filter/regulator and the other fitting with a short piece of hose is a test. I'll pull the supply line out and push the home built piece on and then connect it to the filter out side.
In my case I just installed a Corvette regulator/filter (Wix 33737), blocked off the return on the rail and piped the regulator back to the tank. Sounds easy but there are a few problems. first, the fuel rail block off. I used a Russell fitting with a cap which works just as designed. Next was the fittings to go to the "Vette filter/regulator. No room for the OEM fittings so I went with the Dorman plastic ones that do not have a separate positive lock so I lock wired them on.
