Retro Fit Oil Pan
Want to drop an LS Series engine into your old car? I’m contemplating going into production on an oil pan that will allow the LS Series engines to fit ’67-’90 Camaro, ’62-’75 Nova, ’64-’78 Chevelle, and all B-Body, G-Body, ’55-’64 Fullsize GM. This cast aluminum pan would marry the LS series engine to the older style chassis without modifications to the chassis or oil pan. You’d maintain optimal ground clearance as with the older style small block pan. Its wet-sump design eliminates the need for a remote oil filter adaptor and fittings. All transmission mounting points remain intact for electronically controlled transmissions.
Right now I’m just looking for some feedback to see if there are enough folks doing these conversions to warrant the start up.
Jack
Moderator
Mantycarguy, appreciate the efforts, however, please speak to the Website Administrator Adrian Harris (you can PM him with screen nme IB Adrian) about becoming a sponsor in order to solicit and sell to members on this website.
This post will be unlocked when approval is received, thanks.
