My Magnacharged 6.0 Cutlass at the dragstrip
Old 06-24-2009 | 11:19 PM
ryanvv355's Avatar
Default My Magnacharged 6.0 Cutlass at the dragstrip
Finally had the opportunity to get the Cutlass on the strip to do some shakedown runs. It was a terrible day for drag racing today, 95* 70% humidity, and a very hot track. But those conditions meant many people stayed home, So i had the chance to make a ton of passes.
The biggest issues of the night was ridiculously high intake temperatures and non existent traction. At the start of a run the IAT's where about 133* and 180* by the top end, so I know that was absolutely killing me. The massive amount of low end torque the motor makes made launching an interesting task. The only way to get it to hook was a John Force burnout and stalling it to 2k. anymore RPM the tires would blow off and massive tire shake would happen.
Weighed 3,750lbs w/driver
Right off the trailer it went 12.77 @ 109, 2.02 60ft, spinning bad.
bigger burnout and rolling into the throttle went 12.78 @ 109, 2.08 60ft, still spun a bit.
wimpy burnout and a 1500 rpm launch went 12.76 @ 108.5, 2.06 60ft, spun like the first pass.
All those passes I was logging air/fuel ratio and correcting on the next pass. From here on out I got the AFR nailed so I worked on the launch.
Big burnout, 1500rpm launch with an instant pedal 12.285 @ 110.6, 1.82 60ft, no spin.
Same setup as before except 1300rpm launch, 12.30 @ 110.6, 1.84 60ft
Advanced timing 2*, increased shift point from 5800rpm to 6100, made shift timing quicker, 12.21 @ 110.4, 1.82 60ft
Huge burnout, 2k launch 12.17 @ 110.4, 1.77 60ft
John Force burnout, 2k launch 12.14 @ 111, 1.76 60ft
Overall i'm pleased, I wish i could have ran it into the night when it cooled down. I know it has 11's in it the way it is, it was just to darn hot tonight. I saw a maximum of 96% injector duty cycle so I think I am limited on added addition boost until I get new injectors, but I figure with traction, 10# boost, and my hood for areo it should go 11.70's or so.
Sorry no videos this time, it was all about business tonight, but I heard form several accounts that it was the meanest sounding daily driver some people have ever heard
Old 06-24-2009 | 11:23 PM
V8Rumble's Avatar
NICE... Twelve-teens isn't shabby in anyone's book!
(Well, maybe John Force's...)
Old 06-24-2009 | 11:53 PM
350SS's Avatar
Great times especially for the first outing and crummy air
What did you do about your fuel pump situation?
Old 06-24-2009 | 11:59 PM
ryanvv355's Avatar
I got a Walbro 255 in there right now but have a second that will be going in this winter.
I'm anxious to get it going in good air with a set of slicks, I was on 275/65 BFG Drag Radials
Old 06-25-2009 | 07:18 AM
forcd ind's Avatar
wow, since i just got FIOS, i was able to read your whole build
i ended up with the LQ4, but went with a carb, given my weak computer skills, lol-i orig had a turbo 400, but built a 4l80e, which is in it now
i used the vette front acces. drive, and a D1SC Procharger for a vette, with a Procharger Intercooler
my best time to date (with a turbo 400) was 10.68 @ 126, 9.6 lbs boost under the carb-took it on a 400 mile trip, milage was around 17, but had the carb setup rich-FI would def clean it up, but 60 MPH @ 1900 rpms is pretty cool
i used the stock trans x mem., just cut the mount off and slid the x mem under the tailhousing and welded it back on the other side-i wanted the hump in the x mem for exhaust clear
i built a stroker for it, but been to lazy to install it, lol
i would love to try FI, use a throttle body and have my intake drilled for inj.
prob just switch out my aeromotive reg for an FI unit, keep the same A1000
pump-yea, you got me thinking of FI, lol
did you ever chassis dyno it?
Old 06-25-2009 | 08:44 AM
pist0lpete's Avatar
Nice times Ryan that thing has some 11s in it for sure. I would imagine you will pick up some mph as well if you get some better air.
Old 06-25-2009 | 09:00 AM
rockytopper's Avatar
Congrats ryan nice times especailly first time out and conditions.
Old 06-25-2009 | 01:11 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Very nice, I have a 3800 lb car that will get a supercharged LS engine setup at some point (1951 Merc).
Old 06-26-2009 | 11:43 PM
ryanvv355's Avatar
Ran 11.79 @ 114.5 1.71 60ft tonight with some better air and tuning
Old 06-27-2009 | 12:01 AM
350SS's Avatar
awesome
What afr and timing are you running at?
Old 06-27-2009 | 11:13 AM
ryanvv355's Avatar
11.05:1ish most of the pass and 17.5-19* varying a lot with IAT.
In a perfect world I would be at 11.30-40 and 22* in first and second then 20* for the long pull in third. But after running the 11.79 I didnt want to tune anymore, just run it!
Old 06-27-2009 | 11:47 AM
bagged36's Avatar
wow. congrats
Old 06-27-2009 | 12:45 PM
350SS's Avatar
Sounds like you have your tune dialed in. Is this on pump gas?
Old 06-27-2009 | 01:56 PM
jomomma's Avatar
you`ll be getting kicked off the track if you run much faster!
Old 06-27-2009 | 02:02 PM
quickblue2's Avatar
Pics or this car isnt real
Old 06-27-2009 | 02:09 PM
ryanvv355's Avatar
Yup pump gas 93 octane, heres the proof:
Only my 11.88 pass, the 11.79 vid is LONG!
http://www.youtube.com/watch?v=hEI9bVA8WlU
Old 06-27-2009 | 04:13 PM
alocker's Avatar
What gear do you have?
Nice runs.
Old 06-27-2009 | 09:47 PM
rumblbu's Avatar
Nice car. That magna sounds bad. I see you ran at Martin, that is a very nice track.
Old 06-30-2009 | 02:18 AM
johnnynumber5's Avatar
nice times! what psi you running in the bfg's?
Old 06-30-2009 | 07:24 AM
jbsjunk's Avatar
Damn, I was sitting home Sat nite. Shoulda gone.
Nice pass, sounds good.
Quick Reply: My Magnacharged 6.0 Cutlass at the dragstrip
