tcc 04 gto
Old Jun 24, 2009 | 11:26 PM
randall 32's Avatar
Default tcc 04 gto
im doing a swap 04 gto 4l60e to 240sx. for the tcc wiring it looks like pcm supplies ground to the tcc solenoid gra/red wire 42 green. what i dont know is does the pcm receive a signal from the brake or do i have to cut the gra/red wire and supply ground to the solenoid unless the brake is depressed.please help thanks
Old Jun 28, 2009 | 08:13 PM
randall 32's Avatar
i seen in faq that motors with red and blue connectors supply 12v to 33 blue unless the brake is depressed. is this the same for motors with blue and green connectors? 33 blue on the gto is labeled cruise control release. i know someone out there has done this please help i have been searching and posting with no results.
Old Jun 28, 2009 | 10:20 PM
Smo's04Gto's Avatar
sign up for alldata $25.for one car for one year. Tuff to find stuff on the GTO's when I did my swap 04 gto into the nova wiring and all,alldata help me with the info I could not find on line.You could ask over on ls1gto.com
Old Jun 29, 2009 | 04:54 AM
randall 32's Avatar
thank you
