Single Turbo Ls1 in a 1997 wrangler
Restricted User
Trying to get the Center of gravity as low as possible, plus it gives me plenty of room for the turbo up top.
Sure it only takes about 5 mins to do the swap once you have the alt out. your going to need part # d702se from (http://www.db-starter-alternator.com/). They have them in stock for 19.95. Remove the back cover to the alt there are only 2 screws and one solder point you have to heat up to be able to swap parts. replace with the new one, solder and your done. at that point its a one wire to the battery setup. Super simple to do.
looks friggin great man, i am swapping in a 5.3 i picked up from a 06 avalanche with 29k miles into my 06 rubicon unlimited, had not planned on a power adder but that turbo on yours has got me thinking-- really professional looking work man really
looking good i put a 5.3 in my yj it runs really well i think it would be scary but fun with a turbo i hope u still dont have the dana 30 in the rear because i dont think it will last long
