removing head to fix
Old Jul 5, 2009 | 06:19 PM
xyster's Avatar
Default removing head to fix
I am going to have to remove the head to take it and have a broken header bolt removed and fixed. My question is do I have to use new head bolts when I put it back on, or are the was I took out ok? this is the first time they have been removed.
Old Jul 5, 2009 | 07:21 PM
rotor vs. piston's Avatar
You should use new bolts... head bolts (most all bolts) stretch when they're torqued down. Stupid question... no way to get the bolt out w/o taking the head off... an easy out or something?
Old Jul 5, 2009 | 07:39 PM
jomomma's Avatar
you will definetly want to use new head bolts! they are torque to yeild from the factory.
Old Jul 6, 2009 | 06:02 PM
xyster's Avatar
ok thanks, and i already tried an easy out and it broke in the bolt which the bolt is about 1/4" below the surface of the head so no to the whole welding or vise grip thing also
