Throttle cable recommendation for A-body swap
Do you guys have any recommendations on which cable to use? Part #'s too please if not too much trouble.
My research tells me others have used this lokar piece PN TC-1000LS1 but I can't picture how this part will mount to one of my pedals below. Will I need an anchor fitting of some kind onto the firewall or maybe not?
Man... I wish I had that much room back there. I've got my motor pushed back as close to the firewall as possible - about 3/4" from firewall to passenger side cyl head. What motor mounts are you using?
I guess my car was missing some kinda piece that goes between the pedal and the engine bay...I just made it work.
The other hole is for the kickdown cable. Some were mounted on the pedal and not the carb. If you have a manual trans you might not have had one.. just guess on my part.
