Is this engine/harness combo compatible?
Old Jul 10, 2009 | 07:04 AM
1936 LS1's Avatar
Default Is this engine/harness combo compatible?
I bought a complete harness and PCM from an '05 Silverado (5.3) I have and iron block 5.3 (LM7) and an aluminum 5.7(LS1). I'm using the 5.3 for mock up in my street rod.
My questions are:
What crank/reluctor setup do I need to use with this harness?
Are the sensors in the same location until you go to a GEN IV harness/motor?
2005 5.3 is still a Gen III motor right?
Thanks,
Richard
Old Jul 10, 2009 | 08:09 AM
the_merv's Avatar
Yes all the Sensors are in the same location as any other Gen III Engine.. your Reluctor more than likely is a 58X.
Old Jul 28, 2009 | 09:50 AM
1936 LS1's Avatar
Is the 58X reluctor the one I'd need to use?
Will the crank in the 5.7 and 5.3 have the same reluctor?
Thanks
