LT1 - 2 holes above oil filter??
Old 07-12-2009, 02:56 PM
aarroyo87's Avatar
Default LT1 - 2 holes above oil filter??
I have 2 hole that go into the block of my LT1. I know one of them is an aux oil pressure sending unit but I'm not sure what the other one is. Also which one is the oil pressure hole? The one that is raised above the block and higher or the lower one? Here is apicture from shbox...
http://shbox.com/1/aux_oil_port.jpg
Old 07-12-2009, 03:17 PM
aarroyo87's Avatar
OK I figured it out. The top hole goes into the bell housing area and not into the inside of the block.
Old 07-12-2009, 03:23 PM
the_merv's Avatar
Plug that thing..I forgot to do it on mine and had Oil pouring out when I started it and I was like WTF.. Then I looked and found it.
Old 07-12-2009, 05:43 PM
aarroyo87's Avatar
The bottom hole is plugged. I top hole is left open. Is that OK?
Quick Reply: LT1 - 2 holes above oil filter??
